Costas_B
Use values of field members from different movies
May 23, 2012 6:39 AM
Hi all,
i'm using a different movie in each exercise i'm creating, e.g. exer1.dir, exer2.dir etc etc. I'm putting the same global variable for the students grade in each movie to a field member e.g. field member -> score1 for movie exer1.dir ,  field member -> score 2 for movie exer2.dir etc .
How can i gather all the values from the field members in each movie and put them in a new field member that will contain all these values?
Thank you in advance,
Costas--
    May 23, 2012 6:53 AM   in reply to Costas_B
    You could use setPref to store the values locally, and getPref to retrieve them.
    May 23, 2012 1:35 PM   in reply to Costas_B
    You could use a (single) global property list:
    -- #movie script (in the first movie)
    global gScores
    on prepareMovie
      if voidP(gScores) then gScores = [:]
    end
    -- when you need to store a value
    global gScores
    --... (within some handler definition)
    gScores["score1"] = 50
    --... etc.
    May 25, 2012 6:21 AM   in reply to Costas_B
    It might be easier to use a linear list instead of a property list.
    global gScores
    on prepareMovie
      if voidP(gScores) then gScores = []
    end
    Later.....
    gScores[1] = 50
    gScores[2] = 30
    gScores[3] = 80
    gScores[4] = 62
    Output scores.....
    repeat with Cnt = 1 to gScores.count
       put "Score " & Cnt & " = " & gScores[Cnt]
    end repeat
    May 25, 2012 7:38 PM   in reply to Costas_B
    q: the number 50 in what is referring? The grade of the student?
    Yes ...
    Also ,at the last page where i want all the grades from all exercises how shall i retrieve the values of "score1", "score2"....etc ? Calling gScores["score1"]..etc ?
    ... and yes
