dynamicMovieClip into a SP
May 23, 2012 4:42 AM
I've got a movieClip on stage. (StudentsAttendance_mc) This clip keeps on updating untill frame 10, then in frame 11 I need this movieclip to be seen inside a scrollPane. How do I do this?
I tried creating a empty movieclip (temp_mc) with a linkageID and then used duplicateMovieClip inside temp_mc to see if I can create a duplicate of it and send it to the ScrollPane using contentPath - but no success
  • kglad
    Jul 21, 2002
    May 23, 2012 7:40 AM   in reply to Ron Colmen
    you can't reparent objects in as2 so you'll either need to use as3 or fake it (eg, add a copy of your movieclip to your scrollpane)
  • kglad
    Jul 21, 2002
    May 23, 2012 8:30 AM   in reply to Ron Colmen
    assign your on-stage movieclip a linkage id.
  • kglad
    Jul 21, 2002
    May 23, 2012 9:55 AM   in reply to Ron Colmen
    correct.
    they are not the same instance.  ie, your on-stage movieclip is not the same as the one added to your sp.
    you'll need to update the sp's instance (using the sp.content property) and you'll need to remove your on-stage instance when you want to make it appear as if you're reparenting the on-stage movieclip.
  • kglad
    Jul 21, 2002
    May 23, 2012 10:25 AM   in reply to Ron Colmen
    on frame 11 of StudentsAttendance_mc, you should have:
    _parent.addToSP();
    this.swapDepths(this._parent.getNextHighestDepth());
    this.removeMovieClip();
    then on the parent timeline you should have
    function addToSP():Void{
    sp.contentPath="studentattendancelinkageid";
    sp.content.gotoAndStop(11);
  • kglad
    Jul 21, 2002
    May 23, 2012 11:16 AM   in reply to Ron Colmen
    use the trace() function to make sure the frame 11 is playing and addToSP() is being called.
  • kglad
    Jul 21, 2002
    May 23, 2012 11:53 AM   in reply to Ron Colmen
    use:
    trace ("noProblem!!"); // not showing this
    _parent.addToSP();
  • kglad
    Jul 21, 2002
    May 23, 2012 3:06 PM   in reply to Ron Colmen
    then that frame is not being played.
  • kglad
    Jul 21, 2002
    May 23, 2012 10:37 PM   in reply to Ron Colmen
    use the trace() function to confirm frame 11 is executing and, if it is, to also confirm addToSP() is executing.
  • kglad
    Jul 21, 2002
    May 24, 2012 4:54 PM   in reply to Ron Colmen
    use the trace function to debug:
    trace(this._parent.getNextHighestDepth());  // if that's undefined, you're not publishing for fp less than 8.  either change or manually control depths.
    _parent.addToSP();
