Selecting a Single Clip (CS6)
May 23, 2012 3:41 AM
Selecting a Single clip with Alt+Click while multiple selected clips are selected doesn't work anymore
Now we have to first use Deselect All command or find an empty space and click there to deselect currently selected clips then use Alt+Click.
Feature Request/Bug Report Form
  ******BUG******
Concise problem statement: Selecting a Single Clip with Alt+Click when Multiple is selected
Steps to reproduce bug:
1.Select Multiple Clips
2.Try to select Single Clip with Alt+Click
Results:Selection not chanegs
Expected results:Single Clip should be selected
Link: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    May 23, 2012 7:35 AM   in reply to Steven Pribilinskiy
    Shift Click Should do what you want.
    Alt Click overrides the link between vidieo and audio on a single clip.
    Gaz
    May 23, 2012 8:27 AM   in reply to Steven Pribilinskiy
    you have to perform a Deselect All command or find an empty space and click there to deselect currently selected clips and only then you can use Alt+Click.
    So...do that.
    Not sure this is a bug, just different.
    May 23, 2012 8:35 AM   in reply to Steven Pribilinskiy
    I fail to see your logic.
    You select thirty clips. OK. All these thirty clips are selected. Nothing wrong here.
    Next step is to change your selection, you no longer want 30 clips, you only want one. So what stops you from selecting that single clip?
    It looks like you first select a bowl of cherries. Great, but then you want to narrow down your search to a single cherry and that of course means deselecting all other cherries.
    What am I missing here?
    May 23, 2012 8:36 AM   in reply to Steven Pribilinskiy
    it's definitely a drawback.
    Meh...not so much for me.  There are probably a few dozen bugs/improvements that are far more critical.
    May 23, 2012 9:50 AM   in reply to Jim Simon
    Going from multiple selected clips to just one video or audio clip is one mouse click more then in CS5.5.
    CS6 requires more mouse clicking as in CS5.5.
    May 23, 2012 12:01 PM   in reply to Steven Pribilinskiy
    I was doing that frequently
    It might be better to figure out why you keep selecting the wrong clips in the first place, and then change that.
