Is this just the way it is or am I doing it wrong.
May 22, 2012 2:00 PM
Hi all.
While everything works just fine, whenever I have a dynamic link to AE the render times can be, well, painful. So today I tried something. I rendered the same opening sequence out, as a lossless best setting (AVI 1920X1080) in AE and it took 59 seconds. I imported it into my PPro sequence and rendered it out as .264 and that took 27 seconds.
If I have a dynamic link to the same sequence in AE from PPro the render is around 17 minutes.
Am I doing sometihng wrong ? Or is that the price you pay for convenience ?
System Setup
AMD 955BE Phenom II Quad Core
16GB of 1600 Ram
EVGA GTX560
HDD are 3 X 1 TB, OS, Source and Target.
    May 22, 2012 7:03 PM   in reply to deimosphobos
    I'm inclined to believe the former.  My own tests showed the same render times for both methods (just slightly faster from PP, actually).
    Do you have hardware acceleration active?  Did you have Max Render Quality checked in the PP export?
    May 23, 2012 9:10 AM   in reply to deimosphobos
    I don't have 5.5, but I tested in both 5 and 6.  In both cases, the PP export was actually a little faster than the direct AE export using the same export settings.
