can i delete ALL files in directory ?
Engaged ,
May 23, 2012 May 23, 2012
i create a upload test using FileReference & PHP.
In this scenario user upload files to http server.
Now how can i delete all files in /files/uploads folder in AS3
AS3 Code:
req = new URLRequest();
req.url = ( stage.loaderInfo.parameters.f )? stage.loaderInfo.parameters.f : "http://www.website.com/test/upload.php";
uploadFile = new FileReference();
select_btn.addEventListener( MouseEvent.CLICK, browse );
uploadFile.addEventListener( Event.COMPLETE, complete_func );
uploadFile.addEventListener( DataEvent.UPLOAD_COMPLETE_DATA, show_message );
function browse( e:MouseEvent )
          filefilters = [new FileFilter('Images',"*.jpg;*.png;*.gif")];
          uploadFile.browse( filefilters );
function complete_func( e:Event )
          trace( 'complete !' );
function show_message(e:DataEvent)
if (e.data == 'ok')
          label_txt.text = 'The file has been uploaded.';
else if ( e.data == 'error')
          label_txt.text = 'The file could not be uploaded.';
PHP Code:
<?php
$uploads_dir = './files/uploads';
if( $_FILES['Filedata']['error'] == 0 ){
          if( move_uploaded_file( $_FILES['Filedata']['tmp_name'], $uploads_dir.$_FILES['Filedata']['name'] ) ){
                    echo 'ok';
                    exit();
echo 'error';
exit();
ActionScript
1.3K
Enthusiast ,
You need call another PHP file
<?php
   $directory = './files/uploads';
   getDirectoryList ($directory);
   //This function find all the files in the directory
   function getDirectoryList ($directory)
     // create an array to hold directory list
     $results = array();
     // create a handler for the directory
     $handler = opendir($directory);
     // open directory and walk through the filenames
     while ($file = readdir($handler)) {
       // if file isn't this directory or its parent, add it to the results
       if ($file != "." && $file != "..") {
    //$results[] = $file;
     // Delete Files
    $filename = $file;
unlink($filename
); //this delete a file
     // tidy up: close the handler
     closedir($handler);
Engaged ,
how to call this script from flash?
Enthusiast ,
var request:URLRequest = new URLRequest ("deletFiles.php");
var loader:URLLoader = new URLLoader (request);
//loader.addEventListener(Event.COMPLETE, onComplete);
loader.load(request);
Engaged ,
i tried this but not working....
my code:
var request:URLRequest = new URLRequest ("http://www.site.com/test/deletfiles.php");
function onComplete(e:Event):void
          trace("Complete");
PHP
<?php
    $filename = $file;
    unlink($filename); //this delete a file
    closedir($handler);
Enthusiast ,
Change:
<?php
    $filename = $file;
    closedir($handler);
for this:
<?php
     $results = array();
                  $filename = $file;
unlink($filename);
     closedir($handler);
Engaged ,
i'm facing same problem. i think problem is in flash loader.
if i enter wrong path flash showing : trace complete.
Enthusiast ,
if Flash trace "complete" this means that the loader is working.
Copy some files to the folder and try testing the PHP script
in a navigator go to:
(where site is your real domain)
