can i delete ALL files in directory ?
May 23, 2012 6:44 AM
i create a upload test using FileReference & PHP.
In this scenario user upload files to http server.
Now how can i delete all files in /files/uploads folder in AS3
AS3 Code:
req = new URLRequest();
req.url = ( stage.loaderInfo.parameters.f )? stage.loaderInfo.parameters.f : "http://www.website.com/test/upload.php";
uploadFile = new FileReference();
select_btn.addEventListener( MouseEvent.CLICK, browse );
uploadFile.addEventListener( Event.COMPLETE, complete_func );
uploadFile.addEventListener( DataEvent.UPLOAD_COMPLETE_DATA, show_message );
function browse( e:MouseEvent )
          filefilters = [new FileFilter('Images',"*.jpg;*.png;*.gif")];
          uploadFile.browse( filefilters );
function complete_func( e:Event )
          trace( 'complete !' );
function show_message(e:DataEvent)
if (e.data == 'ok')
          label_txt.text = 'The file has been uploaded.';
else if ( e.data == 'error')
          label_txt.text = 'The file could not be uploaded.';
PHP Code:
<?php
$uploads_dir = './files/uploads';
if( $_FILES['Filedata']['error'] == 0 ){
          if( move_uploaded_file( $_FILES['Filedata']['tmp_name'], $uploads_dir.$_FILES['Filedata']['name'] ) ){
                    echo 'ok';
                    exit();
echo 'error';
exit();
    May 23, 2012 7:52 AM   in reply to Venkom
    You need call another PHP file
    <?php
       $directory = './files/uploads';
       getDirectoryList ($directory);
       //This function find all the files in the directory
       function getDirectoryList ($directory)
         // create an array to hold directory list
         $results = array();
         // create a handler for the directory
         $handler = opendir($directory);
         // open directory and walk through the filenames
         while ($file = readdir($handler)) {
           // if file isn't this directory or its parent, add it to the results
           if ($file != "." && $file != "..") {
        //$results[] = $file;
         // Delete Files
        $filename = $file;
    unlink($filename
    ); //this delete a file
         // tidy up: close the handler
         closedir($handler);
    May 23, 2012 9:44 AM   in reply to Venkom
    var request:URLRequest = new URLRequest ("deletFiles.php");
    var loader:URLLoader = new URLLoader (request);
    //loader.addEventListener(Event.COMPLETE, onComplete);
    loader.load(request);
    May 23, 2012 11:20 AM   in reply to Venkom
    Change:
    <?php
        $filename = $file;
        unlink($filename); //this delete a file
        closedir($handler);
    for this:
    <?php
         $results = array();
                      $filename = $file;
    unlink($filename);
         closedir($handler);
    May 23, 2012 1:07 PM   in reply to Venkom
    if Flash trace "complete" this means that the loader is working.
    Copy some files to the folder and try testing the PHP script
    in a navigator go to:
    http://www.site.com/test/deletfiles.php
    (where site is your real domain)
