Flex Hslide help
May 23, 2012 8:28 AM
Need help with this:
I want the slide value in an Variable I can use other place in program. The slide have the value 0-100.
Code:
protected function hslide_changeHandler(event:Event):void
                           I need the value in a variable here...
Thanks for any help!
    May 23, 2012 8:38 AM   in reply to fsoender
    Did you try
    someVariable = event.target.value;
    May 23, 2012 10:59 AM   in reply to fsoender
    try this
    someVariable = HSlider(event.target).value;
    You may want to listen to the changeEnd event instead of the change event. The change event will continuously fire as the user is moving the slider.
    The changeEnd event fires when they are done moving the slider.
    May 23, 2012 1:08 PM   in reply to fsoender
    What is the error you get with HSlider(event.target).value; ?
    what is the type of the variable to which you are assigning the value?
    May 23, 2012 1:56 PM   in reply to fsoender
    If you want the current value selected by the user with the hslide you
    // declare your variable as a 'Number' because HSlider.value is a Number...
    public var newValue:Number;
    // inside your event handler, assign the current Value of your HSlider to the variable...
    newValue = HSlider(event.target).value;
    Your problem may have been the variable type all along.
