Hello -
I am using FlashEFF for a few text effects in our online advertising banners. I have five embedded fonts. Now the problem is that the file size is huge due to the embedded fonts.
Is it true that if a user does not have that font on their computer that they will see a default font?
I am using the following fonts:
Helvetica Neue: 65 Medium, 77 Bold Condensed, 95 Black
and
Futura LT: Bold and Book
Thank you for any guidance on this.
When you embed a font, you can embed only some characters
Select the textfield (Dynamic or input) press "Embed" button deselect all the "Character Ranges" and type the characters to use in the section "Also include these characters"
If you are using static text, you don´t need embed fonts, everybody see your fonts with static text.
Hi -
I have another question. Just as an experiment I deleted the embedded fonts within the dynamic text boxes. I then tested on a laptop (PC) which does not have those specific fonts on the system. However, I was still able to see the correct fonts within the dynamic text fields. How is this possible?
Thanks!!!
I just read that Helvetica is now considered a "web-safe" font so I am guessing it is okay to remove the Helvetica embedded font from the dynamic text boxes that we use it in. We changed the one Futura font to Helvetica. I am guessing that this is why other computers without those fonts can still see the banner correctly (because Helvetica is a web-safe font).
I can also see the Futura without it being embedded but I have not been able to find documentation that this font is web-safe.
Each font we are using is only listed one time.
Below is a response I received from another forum which is also helpful to know.
"When you use static text, Flash automatically embeds the characters you used as part of the SWF. If you are using dynamic text, you need to embed the entire font for it to work properly, otherwise Flash will default to the behavior with static text, and it will just embed the characters you used in the file. So if for example you entered "placeholder text" in the field, the characters in that string will be exported, but not the rest of the font."
