LuAnnKlann
attach docs in 10.1.3
May 23, 2012 11:55 AM
Tags: #attachments
How do we enable attaching docs to a pdf in Security Properties?
  • George Johnson
    Aug 11, 2002
    May 23, 2012 12:05 PM   in reply to LuAnnKlann
    There are two ways Reader can attach documents to an enabled PDF, either as normal file attachments or as comments. The latter can be enabled with Acrobat or LiveCycle Reader Extensions, but the former can only be enabled with LiveCycle Reader Extensions. It is not done through the security settings in any case.
  • George Johnson
    Aug 11, 2002
    May 23, 2012 12:16 PM   in reply to LuAnnKlann
    Can you describe the specific steps that you're using to attach documents with Adobe Reader 9.5?
  • George Johnson
    Aug 11, 2002
    May 23, 2012 12:32 PM   in reply to LuAnnKlann
    Can you confirm that you're using Reader to do that, as opposed to Acrobat?
  • George Johnson
    Aug 11, 2002
    May 23, 2012 12:33 PM   in reply to LuAnnKlann
    Yes, it almost certainly is the full version (Acrobat).
  • George Johnson
    Aug 11, 2002
    May 23, 2012 12:38 PM   in reply to LuAnnKlann
    OK, that's the reason for the difference you're seeing. You can enable a document for commenting using Acrobat 9 Standard and Reader 10 will be able to add attachments as comments. To do so in Reader, select "Comment > Annotations" and you'll see the "Attach File" tool. It looks like a paperclip.
    May 23, 2012 1:29 PM   in reply to LuAnnKlann
    There is no Reader Standard. There is Adobe Reader and there is Adobe Acrobat Standard and Adobe Acrobat Professional. Adobe Reader is a free program, Adobe Acrobat is a commercial product used for creating pdfs and adding enhancements to alreadly created pdf files.
Bookmarked By (1)
