elements trial version does not finish installation
May 23, 2012 12:54 PM
i downloaded photoshop elements trial version on my laptop at work and want to install it on my private computer. I use the downloaded files. The setup interrupted several times at some point where it can't temporarily safe a .mst file (never the same file). I closed Kaspersky Antivirus and Zonealarm Firewall but the error is still there. No other programs are running during the installation. I don't want to download it again, since my internet connection at home is so slow that it takes a whole day to download this huge installation file. What can i do?
Many thanks,
Michael
    May 23, 2012 1:14 PM   in reply to Beholder72
    Have you tried running the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ to identify what might be causing your difficulties?
    May 23, 2012 1:30 PM   in reply to Beholder72
    Please do try running the Adobe Support Advisor.  It reviews your installation logs and will be able to review your errors in more detail.
    May 23, 2012 1:50 PM   in reply to Beholder72
    Did it identify any troubleshooting documents for you to review to resolve your difficulties?
    May 23, 2012 1:57 PM   in reply to Beholder72
    Which document did it identify?  You are also welcome to manually review the installation logs yourself by following the steps listed at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
    May 23, 2012 2:17 PM   in reply to Beholder72
    Ok I have reviewed your logs as well and I located the following errors:
    DS011 which is stating it is having problems with the content of your install files.
    Do you have access to another computer with a faster Internet connection?  You could download the install files on that other computer and copy them via USB drive to your computer at home?
    I did also look for the return value 3 error but was unable to find anything so you are right it does not appear the analyzer found anything actionable.  This is why sometimes it is neccessary to review the log files manually.
