CS6 Extended - Crashing Like Crazy
May 11, 2012 2:01 PM
Mac Pro; Mac OS 10.7.3; 16GB ram; ATI Radeon HD 5770 1024 MB
Just installed CS6 Extended a couple of days ago, after deinstalling the beta and verifying permissions.
I seem to be crashing a lot - I'd say half a dozen times over the past day or so. I make a path (e.g. a simple rectangle), 3D layer from that path, then start to work with extrusion and revolving the extrusion. All of a sudden, the object will disappear from view, though its representation still appears on the layer thumbnail. I'll click different layers, trying to get the object back, then the program crashes. I've sent all the reports to Adobe.
The beta rarely crashed on me at all; but this release seems very unstable. I'm not able to get anything done in the 3D module without eventually crashing per the above.
Is anyone experiencing similar problems?
Replies 1 2 Previous Next
    May 11, 2012 3:10 PM   in reply to JoeLigo
    I found a few reports with your email address - and you're crashing in MacOS OpenGL drivers.
    This appears to be a bug that Apple introduced in MacOS 10.7.3, and is limited to certain "deprecated" cards (according to Apple).
    It doesn't appear to be fixed in 10.7.4. We have informed Apple, and provided them with the crash report data for them to diagnose the problem.
    Until Apple can fix their driver code, you may want to turn off the GPU features in Photoshop's preferences.
    May 11, 2012 3:21 PM   in reply to JoeLigo
    Do you submit the crash reports with this (rochester.rr.com) domain? If so we have a bug report and are investigating.
    If the domain isn't yours, let me know and I can contact you to get more info.
    regards,
    steve
  • Noel Carboni
    Dec 23, 2006
    May 12, 2012 10:43 AM   in reply to JoeLigo
    I have a Radeon HD 5670 with 1 GB of DDR5 display RAM on my PC (not Mac), and I don't have any problem running Photoshop CS6 smoothly and interactively.    This card is PLENTY powerful enough to run Photoshop.
    Your 5770 is more powerful by about 30% than my 5670.
    Honestly, I'd suspect anyone telling you your card is underpowered of pulling your leg.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 12, 2012 11:25 AM   in reply to JoeLigo
    Yes, I can believe that's true.  This is the downside of Apple having to approve every driver update before it becomes available to customers.  The upside is that only good versions are supposed to get out there.
    When the dust settles from the Photoshop CS6 release things will likely get better.  I'm a little surprised though, that this hasn't already had more attention paid to it, since Photoshop CS6 beta has been out for a couple of months already.  Plus, while there were a couple of hiccups, ATI has done a pretty good job lately with their drivers on the PC side; I'd expect good quality from them on the Mac as well.
    In the interim, as a workaround have you tried the various advanced Graphics Processor settings available in Photoshop - Preferences - Performance?
    -Noel
    May 12, 2012 11:30 AM   in reply to JoeLigo
    No conflict. And that card is not underpowered (it would probably work perfectly in 10.6.8 or 10.7.2).
    We tested the 5770 quite a bit, and it worked fine - until 10.7.3 was released.
    Apple introduced a bug in their OpenGL drivers in 10.7.3, but it only affects certain cards.
    When we asked Apple about this, the cards that are affected are on their "deprecated" list.  I can make guesses about how an engineer might make a mistake based on that information, but I don't know for certain, and we don't have access to Apple's code to know what the exact mistake might be.
    We are talking to Apple about this, but it doesn't currently appear that Adobe can do anything about the driver bug -- we probably have to wait for Apple to fix it.
  • Noel Carboni
    Dec 23, 2006
    May 13, 2012 6:47 AM   in reply to JoeLigo
    That sounds very much like the kind of instability a driver can cause.
    I believe you'll be able to either lower the Photoshop GPU usage to "Basic" or disable it entirely and see an improvement in stability.
    -Noel
    May 13, 2012 8:36 AM   in reply to Noel Carboni
    Photoshop 5.5 and beta 6 workrd fine in OSX 10.7.4. When in the released version of CS6, the 3D Environment is literaly useless. Any attempt to save in 3D, attemp to alter color, and render with reflection effects crashes Photoshop. The GPU is at "basic", when turned off the 3D environment is not accessible. Mac Pro , 32 gb ram, 4 - 480gb SSD drives & NVIDIA GeForce 7300 GT 256 MB. The fact that version prior to the CS6 release were working has me puzzled. To be sure, I just duplicated my CS6 attempted project in CS5 at it prefomed flawlessly.
    May 13, 2012 12:40 PM   in reply to JoeLigo
    Yes, that sounds like the video card driver, but could also be related to bugs in Spaces (which Apple so far has not fixed).
    7300 GT - that shouldn't be available for 3D in the first place, that driver is known NOT to work correctly (and it was disabled in previous versions of Photoshop as well).
    Could you please post your Help->System Info log?
    May 13, 2012 3:25 PM   in reply to gwbeers
    Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
    Operating System: Mac OS 10.7.4
    System architecture: Intel CPU Family:6, Model:15, Stepping:6 with MMX, SSE Integer, SSE FP, SSE2, SSE3
    Physical processor count: 4
    Processor speed: 2660 MHz
    Built-in memory: 32768 MB
    Free memory: 24698 MB
    Memory available to Photoshop: 31271 MB
    Memory used by Photoshop: 80 %
    Image tile size: 1024K
    Image cache levels: 4
    OpenGL Drawing: Enabled.
    OpenGL Drawing Mode: Basic
    OpenGL Allow Normal Mode: False.
    OpenGL Allow Advanced Mode: False.
    OpenGL Allow Old GPUs: Not Detected.
    OpenGL Version: 2.1 NVIDIA-7.0.52
    OpenCL Unavailable
    Video Card Vendor: NVIDIA Corporation
    Video Card Renderer: NVIDIA GeForce 7300 GT OpenGL Engine
    Display: 1
    Main Display
    Display Depth:= 32
    Display Bounds:=  top: 0, left: 0, bottom: 1600, right: 2560
    Video Renderer ID: 16917516
    Video Card Memory: 234 MB
    Video Rect Texture Size: 4096
    Serial number: xxxxxxxxxxxxx
    Application folder: Glenn's Mac:Applications:Adobe CS 6:Adobe Photoshop CS6:
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      Glenn's Mac, 223.3G, 129.1G free
    Required Plug-ins folder: Glenn's Mac:Applications:Adobe CS 6:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
    Primary Plug-ins folder: Glenn's Mac:Applications:Adobe CS 6:Adobe Photoshop CS6:Plug-ins:
    Additional Plug-ins folder: not set
    Installed components:
       adbeape.framework   adbeape   3.3.8.19346   66.1025012
       AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
       adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
       AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
       AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
       AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
       AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
       AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
       AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
       AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
       AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
       AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
       AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
       AdobeLinguistic.framework      17206
       AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
       AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
       AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
       AdobePDFSettings.framework   AdobePDFSettings   1.4
       AdobePIP.framework   AdobePIP   6.0.0.1654
       AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
       AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
       AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
       AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
       AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
       ahclient.framework   ahclient   1.7.0.56
       aif_core.framework   AdobeAIF   3.0.00   62.490293
       aif_ocl.framework   AdobeAIF   3.0.00   62.490293
       aif_ogl.framework   AdobeAIF   3.0.00   62.490293
       AlignmentLib.framework   xcode   1.0.0.1
       amtlib.framework   amtlib   6.0.0.75
       boost_date_time.framework   boost_date_time   6.0.0.0
       boost_signals.framework   boost_signals   6.0.0.0
       boost_system.framework   boost_system   6.0.0.0
       boost_threads.framework   boost_threads   6.0.0.0
       Cg.framework   NVIDIA Cg
       CIT.framework   CIT   2.0.5.19287   145486
       data_flow.framework   AdobeAIF   3.0.00   62.490293
       dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
       dvacore.framework   dvacore   6.0.0.0
       dvamarshal.framework   dvamarshal   6.0.0.0
       dvamediatypes.framework   dvamediatypes   6.0.0.0
       dvaplayer.framework   dvaplayer   6.0.0.0
       dvatransport.framework   dvatransport   6.0.0.0
       dvaunittesting.framework   dvaunittesting   6.0.0.0
       dynamiclink.framework   dynamiclink   6.0.0.0
       FileInfo.framework   FileInfo   66.145433   66.145433
       filter_graph.framework   AdobeAIF   3.0.00   62.490293
       hydra_filters.framework   AdobeAIF   3.0.00   62.490293
       ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
       ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
       image_compiler.framework   AdobeAIF   3.0.00   62.490293
       image_flow.framework   AdobeAIF   3.0.00   62.490293
       image_runtime.framework   AdobeAIF   3.0.00   62.490293
       LogSession.framework   LogSession   2.1.2.1652
       mediacoreif.framework   mediacoreif   6.0.0.0
       PlugPlug.framework   PlugPlug   3.0.0.383
       UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
       wrservices.framework
    Required plug-ins:
       3D Studio 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
       ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
       Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Average 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
       Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
       Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Cineon 13.0 20120315.r.428 2012/03/15:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
       Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
       Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
       Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
       Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
       Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
       Embed Watermark NO VERSION - from the file “DigiSign.plugin”
       Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
       Entropy 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
       Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Flash 3D 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Google Earth 4 KMZ 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
       IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
       Kurtosis 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
       Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
       Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
       Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
       Maximum 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Mean 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
       Median 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Minimum 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
       Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Multiprocessor Support 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
       Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
       Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
       OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       PCX 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
       Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
       Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
       Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Pixar 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
       Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
       Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Radiance 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
       Range 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Read Watermark NO VERSION - from the file “DigiRead.plugin”
       Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
       ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
       Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Skewness 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Solarize 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
       Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Standard Deviation 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Summation 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       U3D 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
       Variance 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Wavefront|OBJ 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
       ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
    Optional and third party plug-ins:
       Alien Skin Autolayer 3 Autolayer 3 3.0.0 15815 2010-08-03 10:26 Copyright © 2010 Alien Skin Software, LLC - from the file “Alien Skin Autolayer 3.8li.plugin”
       Alien Skin Blow Up 2 Batch Blow Up 2 Batch Automation 2.1.1.1146 17236 Copyright © 2009 Alien Skin Software, LLC - from the file “Blow Up 2 Batch Automation.plugin”
       Alien Skin Blow Up 2 Blow Up 2 Automation 2.1.1.1146 17236 Copyright © 2009 Alien Skin Software, LLC - from the file “Blow Up 2 Automation.plugin”
       Anaglyph Flip AnaglyphFlip 1.6.0 ©2011 Flaming Pear Software - from the file “AnaglyphFlip.plugin”
       Animal Fur Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       AntiGhost AntiGhost 1.6.0 ©2011 Flaming Pear Software - from the file “AntiGhost.plugin”
       AutoEye 2 �1993-2010 Auto FX Incorporated - from the file “AUTOEYE-64bit.plugin”
       BackgroundFilter NO VERSION - from the file “BackgroundFilter.plugin”
       Backlight Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Bevel Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Black and White Film Exposure 3 3.0.6.1114 17623 Copyright © 2009 Alien Skin Software, LLC - from the file “Alien Skin Exposure 3.8bf.plugin”
       Blemish Concealer Image Doctor 2 2.1.1.1069 17283 Copyright © 2007 Alien Skin Software, LLC - from the file “Image Doctor 2.plugin”
       Blow Up 2 Batch UI Blow Up 2 2.1.1.1146 17236 Copyright © 2009 Alien Skin Software, LLC - from the file “Blow Up 2.plugin”
       Blow Up 2 Render Blow Up 2 2.1.1.1146 17236 Copyright © 2009 Alien Skin Software, LLC - from the file “Blow Up 2.plugin”
       Blow Up 2 UI Blow Up 2 2.1.1.1146 17236 Copyright © 2009 Alien Skin Software, LLC - from the file “Blow Up 2.plugin”
       Bokeh Bokeh 2 2.0.1.377 17620 Copyright © 2010 Alien Skin Software, LLC - from the file “Alien Skin Bokeh 2.8bf.plugin”
       Brick Wall Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Brushed Metal Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Burnt Edges Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       ChromaSolarize ChromaSolarize 1.6.0 ©2011 Flaming Pear Software - from the file “ChromaSolarize.plugin”
       Chrome Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Circle to Square Circle To Square 1.6.0 ©2011 Flaming Pear Software - from the file “Circle To Square.plugin”
       Classic Mosaic Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       Color Efex Pro 4 4.000, Copyright © 2000-2011 Nik Software Inc. - from the file “Color Efex Pro 4.plugin”
       Color Film Exposure 3 3.0.6.1114 17623 Copyright © 2009 Alien Skin Software, LLC - from the file “Alien Skin Exposure 3.8bf.plugin”
       Color Pencil Snap Art 2 2.1.1.1029 17510 Copyright © 2011 Alien Skin Software, LLC - from the file “Snap Art 2.plugin”
       Comics Snap Art 2 2.1.1.1029 17510 Copyright © 2011 Alien Skin Software, LLC - from the file “Snap Art 2.plugin”
       Constellation Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       Corona Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Cracks Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       Crumple Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       Demitone 25 Demitone 25 1.6.0 ©2011 Flaming Pear Software - from the file “Demitone 25.plugin”
       Demitone 50 Demitone 50 1.6.0 ©2011 Flaming Pear Software - from the file “Demitone 50.plugin”
       Dfine 2.0 NO VERSION - from the file “Dfine2.plugin”
       Diamond Plate Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       DreamSuite �1993-2010 Auto FX Incorporated - from the file “DreamSuite-64bit.plugin”
       Drip Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Dust and Scratch Remover Image Doctor 2 2.1.1.1069 17283 Copyright © 2007 Alien Skin Software, LLC - from the file “Image Doctor 2.plugin”
       Electrify Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       Extensis 3.0.6.37, "Copyright 2010 Extensis, a division of Celartem, Inc.  All rights reserved." - from the file “ExtensisFontManagementPSCS5.plugin”
       Extrude Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       FineStructuresFilter NO VERSION - from the file “FineStructuresFilter.plugin”
       Fire Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Flag Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       Flexify 2 Flexify 2 2.7.0 ©2011 Flaming Pear Software - from the file “Flexify 2.plugin”
       Flood Flood 1.6.0 ©2011 Flaming Pear Software - from the file “Flood.plugin”
       FocalPoint 2 2.0.9 (Suite 6), Copyright © 2011 onOne Software.  All rights reserved. - from the file “FocalPointAutomation.plugin”
       FocalPoint 2 Filter 2.0.9 (Suite 6), Copyright © 2011 onOne Software.  All rights reserved. - from the file “FocalPointFilter.plugin”
       FocalPoint 2 Hidden NO VERSION - from the file “HiddenFilter.plugin”
       Ghost Ghost 1.6.0 ©2011 Flaming Pear Software - from the file “Ghost.plugin”
       Glass Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Gradient Glow Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Gray from Blue Gray from Blue 1.6.0 ©2011 Flaming Pear Software - from the file “Gray From Blue.plugin”
       Gray from Green Gray from Green 1.6.0 ©2011 Flaming Pear Software - from the file “Gray From Green.plugin”
       Gray from Red Gray from Red 1.6.0 ©2011 Flaming Pear Software - from the file “Gray From Red.plugin”
       HDR Efex Pro 1.200, Copyright © 2000-2011 Nik Software Inc. - from the file “HDR Efex Pro Tonemapping.plugin”
       HDR Efex Pro Metadata 1.200, Copyright © 2000-2011 Nik Software Inc. - from the file “HDR Efex Pro Metadata.plugin”
       Hidden Proxy Filter NO VERSION - from the file “PhotoFrame 4.6 Professional Edition.plugin”
       Hidden Topaz Labs Denoise - from the file “TopazRemaskAutomate.plugin”
       HotPixelsFilter NO VERSION - from the file “HotPixelsFilter.plugin”
       HSL -> RGB HSL to RGB 1.6.0 ©2011 Flaming Pear Software - from the file “HSL to RGB.plugin”
       Icicles Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Impasto Snap Art 2 2.1.1.1029 17510 Copyright © 2011 Alien Skin Software, LLC - from the file “Snap Art 2.plugin”
       India Ink India Ink 1.9.94 ©2011 Flaming Pear Software - from the file “India Ink.plugin”
       JPEG Repair Image Doctor 2 2.1.1.1069 17283 Copyright © 2007 Alien Skin Software, LLC - from the file “Image Doctor 2.plugin”
       Kyoto Color Kyoto Color 1.6.0 ©2011 Flaming Pear Software - from the file “Kyoto Color.plugin”
       Lab -> RGB LAB to RGB 1.6.0 ©2011 Flaming Pear Software - from the file “LAB to RGB.plugin”
       Lightning Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       Little Fluffy Clouds Xenofex 2 2.6.1.1078 17365 Copyright © 2007 Alien Skin Software, LLC - from the file “Xenofex 2.plugin”
       Make Cube Tile Make Cube Tile 1.6.0 ©2011 Flaming Pear Software - from the file “Make Cube Tile.plugin”
       Make Iso Cube Tile Make Iso Cube Tile 1.6.0 ©2011 Flaming Pear Software - from the file “Make Iso Cube Tile.plugin”
       Marble Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Merge to HDR Efex Pro 1.200, Copyright © 2000-2011 Nik Software Inc. - from the file “HDR Efex Pro Automation.plugin”
       Motion Trail Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       Mystical 2 �1993-2010 Auto FX Incorporated - from the file “Mystical2-64bit.plugin”
       Nik Selective Tool 2.103, Copyright © 2000-2012 Nik Software Inc. - from the file “SelectivePalette.plugin”
       Oil Paint Snap Art 2 2.1.1.1029 17510 Copyright © 2011 Alien Skin Software, LLC - from the file “Snap Art 2.plugin”
       Ornament Ornament 1.6.0 ©2011 Flaming Pear Software - from the file “Ornament.plugin”
       Pastel Snap Art 2 2.1.1.1029 17510 Copyright © 2011 Alien Skin Software, LLC - from the file “Snap Art 2.plugin”
       Pen and Ink Snap Art 2 2.1.1.1029 17510 Copyright © 2011 Alien Skin Software, LLC - from the file “Snap Art 2.plugin”
       Pencil Sketch Snap Art 2 2.1.1.1029 17510 Copyright © 2011 Alien Skin Software, LLC - from the file “Snap Art 2.plugin”
       Perfect Effects 3.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Effects.plugin”
       Perfect Effects Filter 3.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Effects.plugin”
       Perfect Effects Smart Filter 3.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Effects.plugin”
       Perfect Mask 5.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Mask.plugin”
       Perfect Mask Filter 5.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Mask.plugin”
       Perfect Mask Smart Filter 5.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Mask.plugin”
       Perfect Portrait 1.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Portrait.plugin”
       Perfect Portrait Filter 1.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Portrait.plugin”
       Perfect Portrait Smart Filter 1.0 (Suite 6.0), Copyright © 2011 onOne Software.  All rights reserved. - from the file “Perfect Portrait.plugin”
       Perfect Resize 7.0 Professional Edition 7.0.5, Copyright © 2011 onOne Software.  All rights reserved. - from the file “Automation.plugin”
       Perfect Resize 7.0 Professional Edition Batch 7.0.5, Copyright © 2011 onOne Software.  All rights reserved. - from the file “Batch.plugin”
       Perfect Resize 7.0 Professional Edition Filter 7.0.5, Copyright © 2011 onOne Software.  All rights reserved. - from the file “Filter.plugin”
       Perspective Shadow Eye Candy 6 6.1.1.1058 17502 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
       PGE 7 �1993-2010 Auto FX Incorporated - from the file “PGE7-64bit.plugin”
       PhotoFrame 4.6 Professional Edition 4.6.5 (Suite 6), Copyright © 2011 onOne Software. All rights reserved. - from the file “PhotoFrame 4.6 Professional Edition Automation.plugin”
       PhotoFrame 4.6 Professional Edition Batch 4.6.5 (Suite 6), Copyright © 2011 onOne Software.  All rights reserved. - from the file “PhotoFrame 4.6 Professional Edition Batch.plugin”
       PhotoFrame 4.6 Professional Edition Hidden NO VERSION - from the file “PhotoFrame 4.6 Professional Edition.plugin”
       PhotoTools 2.6 Hidden NO VERSION - from the file “HelperFilter.plugin”
       PhotoTools 2.6 Professional Edition 2.6.4 (Suite 5.5.4), Copyright © 2011 onOne Software.  All rights reserved. - from the file “PhotoTools 2.6 Professional Edition.plugin”
       PhotoTools 2.6 Professional Edition Batch 2.6.4 (Suite 5.5.4), Copyright © 2011 onOne Software.  All rights reserved. - from the file “PhotoTools 2.6 Professional Edition Batch.plugin”
       PhotoTune 3 3.0.9 (Suite 5.5.4), Copyright © 2011 onOne Software.  All rights r
    May 13, 2012 3:27 PM   in reply to gwbeers
    OK, that's weird - I thought that card should be disabled, but it's enabled and "allow old GPUs" isn't installed.
    We'll have to investigate.
    (honestly, the drivers for that card are among the worst known drivers)
    May 14, 2012 7:04 AM   in reply to Chris Cox
    Are there other drivers or firmware updates available for this card, or are you suggesting a replacement? If you're recommendind a replacement , what would you recommend?
    May 14, 2012 7:11 AM   in reply to gwbeers
    It is my understanding with Apple you have to take the drivers that are included with the OS update.
    Windows user so not sure if you can roll back to a previous OS update which may have differet driver update.
    May 14, 2012 7:17 AM   in reply to Curt Y
    I beleive that as well. But can't understand why CS5 (and the CS6 beta) has no problem with the driver and CS6 crashes while preforming identical tasks on the same project.
    May 14, 2012 8:10 AM   in reply to gwbeers
    The 3D infrastructure in CS6 has changed from CS5 and needs more horsepower.  But if CS6 beta worked, CS6 Extended should also as they are virtually the same product.  Bugs identified are still being re-coded.
    May 15, 2012 3:45 PM   in reply to Curt Y
    Swopped the old card for a ATI Radeon HD 5770. All good!
  • Noel Carboni
    Dec 23, 2006
    May 15, 2012 4:49 PM   in reply to gwbeers
    Another ATI success story.  Thanks for reporting back, gw!
    -Noel
    May 23, 2012 1:56 PM   in reply to JoeLigo
    da wn, After a ton of crashes I replaced my old video card with a new one - that helped the most obvious, reoccuring crashes but I still had a few bugs soley in the 3D mode. I spoke with Adobe 6 times with no help and finally the last tech I spoke with told me to uninstall Photoshop and reinstall it. That cured all my 3D problems to date. I now have complete a complete crash-free week! I hope writing this isn't the kiss of death....
  • Noel Carboni
    Dec 23, 2006
    May 23, 2012 5:57 PM   in reply to JoeLigo
    Da wn, what you're experiencing is an exception, rather than the rule.  I know that's of little consolation.
    I am a bit curious, though...  Why did you not download the free trial and ensure that it worked okay on your system before paying the money?
    -Noel
    May 23, 2012 6:05 PM   in reply to JoeLigo
    All programs are likely to crash from time to time -- and the most common bugs causing crashes in Photoshop CS6 aren't in Photoshop itself, but in the OS and third party plugins.
    So even in Basic mode, you may have a different crash due to a different cause.
    Your last reported GPU driver crash that I can find was on May 10.
    You hit a 3D crash on May 23.  We're still testing a fix for that particular issue.
    And you have 2 additional, older reported crashes in similar 3D code (but different enough that they went into different buckets).
    May 24, 2012 5:54 AM   in reply to JoeLigo
    I had the same experience as da wn. I was fine with the Beta in OSX 10.7.4. The release version was the culprit.
    May 24, 2012 9:09 AM   in reply to JoeLigo
    The release version is more stable -- but the crashes you've reported were also present in the beta (just not something we could fix, or further down the list from the critical ones we fixed).
    May 26, 2012 6:22 AM   in reply to JoeLigo
    da wn:
    After the ATI card install and reinstall of CS6, Photoshop launched and defaulted to ADVANCED with all 3 options checked. I haven't experienced any crashes or glitches since. Since the 3D evvironment is a new toy for me, I've been spending alot of time with it and I'm pleased with the performance.
    May 26, 2012 10:46 AM   in reply to JoeLigo
    da wn:
    It's important to due the Adobe "Uninstall" to remove any remnants from prior CS6 installs, before the re-install. I think you'll find the 3D environment very intuitive and a massive jump from 5.5. I played with 3D in 5.5 but it was too time consuming, where in 6, everything is in realtime and you can edit on the fly. Good luck!
    May 29, 2012 11:03 AM   in reply to JoeLigo
    I got that a lot in CS5 & 5.5, but it never had any effect on the files. I didn't matter whether it was a "command-Q", a quit from the dock or from the app. Haven't seen it in 6 - yet
    Jun 12, 2012 9:38 AM   in reply to JoeLigo
    We don't define Apple's standards.... We just have to try and deal with them.
    Jul 16, 2012 2:00 PM   in reply to JoeLigo
    We cannot comment on unreleased versions of Apple software.
    Apple has fixed many bugs in 10.8, but they'll have to make the announcements.
1 2 Previous Next
Bookmarked By (1)
