jcharise
Adobe Photoshop Elements 10
May 22, 2012 8:04 PM
I purchased the software this weekend.  I atttempted to install the first disc and it hung up.  I had to hardboot my laptop.  When I attempted to try the install again, it wouldn't allow me to because it said that the serial number was invalid.  Now, I am not able to use what I purchased, even though the install was incomplete.
Any suggestions on how I may get my monies worth on this purchase?
    May 23, 2012 11:10 AM   in reply to jcharise
    Which operating system are you using?  Do you have any other Adobe software installed?  Did you receive any particular error messages when you try to install?
    May 23, 2012 4:02 PM   in reply to jcharise
    Can you please try running the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ to rview your installation logs.
    May 23, 2012 4:52 PM   in reply to jcharise
    Can you please try removing Adobe Reader and then try moving the following folders temporarily to your desktop:
    Please move the folder which is appropriate to your Operating System
    Windows 32-bit:  \Program Files\Common Files\Adobe\Adobe PCD\
                             \Program Files\Common Files\Adobe\caps\
    Windows 64-bit:  \Program Files (x86)\Common Files\Adobe\Adobe PCD\
                             \Program Files (x86)\Common Files\Adobe\caps\
    Then try installing Adobe Photoshop Elements again.
    May 23, 2012 5:12 PM   in reply to jcharise
    Interesting and you are using Windows 64-bit?  Lets give it a try though please go ahead and reinstall Photoshop Elements.
    If this works then can you please double check to see if you have any other Adobe software installed?
    May 23, 2012 6:58 PM   in reply to jcharise
    Why are using the disc1 to install the software on your computer?
    If I am right you are on the Windows 7 (64 bit) and for that you need to use the Disc 2.
    For details : look DVD description
    So,, Insert Disc 2 directly and start the installation.
    May 24, 2012 11:12 AM   in reply to Manish-Sharma
    Disc two is the Premiere Elements trial.  You should have been able to click on ok and completed the install process.  It also appears we were able to get past the invalid serial number message by moving the Adobe PCD folder to your desktop.  If you have no other Adobe software installed you can delete this folder.
