liangyongning
How to copy Plain Text from TextFlow?
May 22, 2012 8:24 PM
Tags: #paste #copy
Hey guys,  I got stuck on Textflow copy-paste operation, I want to copy plain text from a textflow, don't want any text format/style but InlineGraphics, how can I do this?
    May 22, 2012 8:27 PM   in reply to liangyongning
    Please search Custom Clipboard inside TLF forum and blog.
    http://blogs.adobe.com/tlf/
    May 22, 2012 11:35 PM   in reply to liangyongning
    create a PlainTextExporter extends ConverterBase and implements ITextImporter, and
    TextConverter.addFormatAt(0, "plainText", PlainTextImporter);
    1. Did you create PlainTextExporter but register PlainTextImporter? I believe it must be a typo.
    2. What's more, the fifth paramter of addFormatAt should not be null when you take advantage of Custom Clipboard.
                         * Register a new format for import/export, at the specified location.
                         * Location can be significant for clients that have multiple
                         * choices for which format to use, such as when importing from the external clipboard.
                         * Lower numbers indicate higher priority; these converters will be tried first.
                         * The new format may support importing and/or exporting.
                         * If the format has already been added, then it will be present in multiple locations. The
                         * first one found will be used.
                         * @playerversion Flash 10
                         * @playerversion AIR 1.5
                         * @langversion 3.0
                         * @param importClass    The import converter class to register or null
                         * @param exportClass    The export converter class to register or null
                         * @param format         The format string tagging the converter classes
                         * @param clipboardFormat          The string used as the clipboard format when converting to/from the clipboard. Make this null if the format doesn't support clipboard access.
                        public static function addFormatAt(index:int, format:String, importerClass:Class, exporterClass:Class = null, clipboardFormat:String = null):void
    3. The example in blog only includes a importer. There can also be a exporter. Importer is called when you copy, while exporter when you paste.
    4. You must pay attention to the *if-condition* in importToFlow() of importer.
    May 23, 2012 10:41 PM   in reply to liangyongning
    Please pay attention to the bold words of item 2 in my last reply. You cannot miss the fifth paramter.
    TextConverter.addFormatAt(0, "plainText", PlainTextImporter, PlainTextExporter, "air:text");
    Is TextConverter influences the global copy behaviours in all TextFlows?
    Yes, but you can add if-conditions in importToFlow() to skip it under some circumstances.
    May 24, 2012 2:21 AM   in reply to liangyongning
    Maybe you can refer to the code of flashx.textLayout.conversion.TextConverter,  the default importers and exporters.
    The default clipboard is
    static tlf_internal function setFormatsToDefault():void
          _descriptors = [];
         addFormat(TEXT_LAYOUT_FORMAT, TextLayoutImporter, TextLayoutExporter, TEXT_LAYOUT_FORMAT);
         addFormat(TEXT_FIELD_HTML_FORMAT, TextFieldHtmlImporter,  TextFieldHtmlExporter, null);
         addFormat(PLAIN_TEXT_FORMAT, PlainTextImporter, PlainTextExporter, "air:text");
    Besides, you may want to change the name of your class to avoid unexpected issues. You can see that there is already a TLF importer named PlainTextImporter.
Bookmarked By (1)
