What is the advantage of using Photoshop Extended to incorporate a 3D object, as opposed to importin
May 23, 2012 3:38 PM
Tags: #cs5 #cs6 #photoshop_cs5.1_extended #photoshop_cs6_extended #cs5ex
What is the advantage of using Photoshop Extended to incorporate a 3D object, as opposed to importing from a 3D tool?
The scenario re my usage would be to create a 3D light photograph/layout for a game.  So sometimes being able to create the room from wall planes with textures would be good, and then place some images/objects in the room.
So in this case I'm wondering whether it would be worth to goto "Extended" with the 3D tools.
But the question is, if say you want to incorporate a simple 3D shape in the rooms photo, whether there is any advantage to using Photoshop Extended to do this using it's 3D tools, as opposed to creating the 3D object in a separate tool (e.g. blender) and exporting an image to then incorporate in photoshop.
    May 23, 2012 3:56 PM   in reply to ItsGregHere
    The same question can be asked regarding video.
    Photoshop can do video and 3D but not as well as a dedicated program. The benefit, on basic tasks, is not having to open that other dedicated video or 3D program.
    Just as you can load a 3D object in Photoshop, you can also load a 2D background image in a 3D app. Compositing can happen in eother program. It depends on where you feel most comfortable.
  • Trevor Dennis
    May 24, 2010
    May 23, 2012 5:01 PM   in reply to ItsGregHere
    It would possibly be worth your while Googling Photoshop CS6 3D and working through a few of the video tutoials.  A few days ago they were thin on the ground, but there seem to be more every day.  There is a scattering of the better ones in this flickr group thread.  http://www.flickr.com/groups/photoshopsupport/discuss/7215762973802432 4/
  • Noel Carboni
    Dec 23, 2006
    May 23, 2012 6:43 PM   in reply to ItsGregHere
    I'm not sure the question is being asked specifically enough, to be honest.
    I've little experience with 3D myself, but I can see a definite efficiency advantage to just editing extruded text, for example, then re-rendering in Photoshop.
    With what little experimentation I've done, having the ability to make changes, for example to lighting angles, then seeing the result right away against the background photo allows one to iterate more quickly, and that seems likely to mean you'll be through with something that looks quite realistic more quickly.
    But I don't know whether you're working with 3D objects added to existing photos, or full scene rendering soup to nuts in 3D.
    -Noel
    May 23, 2012 7:04 PM   in reply to ItsGregHere
    I've struggled with this kind of question a while to decide if worth extra $$$ to get CS6 extended vs. std.
    After trial use it is very clear to me...CS6 extended not worth more cost to me. Why? because the 3D tools offer nothing compared to all the other 3D programs I already have and use. Workflow actually easier as I already know my 3D tools and they can be active as same time as Ps so moving files between apps is easy.
    OTOH, I can see that if someone only dabbled in 3D and did not have other 3D programs (even some that are free), then 3D in Ps would be valuable. And there are other "extended" capabilities for scientific work.
    So in the end it is a personal decision based on what kind of work you do and what tools are needed and work well for you.
  • Trevor Dennis
    May 24, 2010
    May 23, 2012 7:05 PM   in reply to ItsGregHere
    If I was a game developer, I'd want all the tools I could lay my hands on.  I'd expect to set them against income tax as well.
    May 24, 2012 12:03 AM   in reply to ItsGregHere
    Assuming each model can be imported into Ps Extended (there's interchange anomalies that can bite you), then what you're asking about arranging and merging to a single scene is possible. Where this might be an advantage done in Photoshop is if the rendering capabilities of your 3D authoring app are limited (no Ray Trace or IBL lighting) compared to those found in Photoshop. It might be a disadvantage if your 3D authoring has rendering capabilities that you would lose bringing it into Ps (caustics, subsurface scattering).
    Compositng into a flat background can work either way, depending on the complexity you're trying to achieve. If you're proficient and comfortable with a 3D authoring application, then that's probably where you want to do your 3D authoring work. If you need to generate complex models, require UV editing, or have rendering needs for highly realistic glass or transparent/translucent materials than you'll need a 3D authoring application.
    regards,
    steve
  • Noel Carboni
    Dec 23, 2006
    May 24, 2012 1:41 AM   in reply to ItsGregHere
    One thing you could consider is to download the trial version, which provides all the features of Photoshop CS6 Extended, and actually try it out for a month.  Try actually doing the kinds of work you're anticipating doing.  You'll get familiar with the tool's capabilities, and you can not only judge the ease of use for your application but also the results quality.
    -Noel
    May 25, 2012 7:04 AM   in reply to ItsGregHere
    If you only plan to do basic stuff then Ps may be a good solution but it is expensive compared to free Blender.
    But Ps is easier to use and Blender has a steep learning curve.
    There are other easier free/low cost simple 3D programs that may be sufficient compared to the premium price of Ps but none are well integrated with Ps; but using layers in Ps with rendered 3D scenes in 2D is easy.
    Importing 3D objects from other 3D programs to Ps has occasional issues but only needed for complex work when Ps can't create internally. But if you have Ps-extd, then need for other 3D is only when more complex 3D is used.
    Jun 1, 2012 2:20 PM   in reply to Doug.S
    For compositing the 3D models I think you will find much of what you need already in Photoshop.
    For modelling, shaders of complex materials (eg fur) > you need a 3D application.
    We support these file formats: OBJ, 3DS, DAE and KMZ (Collada) Blender will support export most if not all of these.
