InDesign CS6 not automatically updating links
May 24, 2012 6:27 AM
In previous verisons of InDesign, if I select a linked file, then click "edit link" from the links panel, the link will open up in Photoshop or Illustrator or whatever program, and once I edit, save, and close the file, when I switch back to InDesign, the file would automatically update. CS6 is not updating. Anyone have any suggestions as to how to fix this issue?
    May 24, 2012 7:02 AM   in reply to chadtrent
    It certainly should be updating. Are you sure it is not? Do you see a modified link warning when you return?
    May 24, 2012 7:41 AM   in reply to chadtrent
    Have you left the linked file open and just gone back and edited again? That used to work, but hasn't for a few versions now. Selecting a link, Edit Original, save in editing app, return to ID,SHOULD update, though.
    If it isn't, the first thing I would try is trash your prefs. See Replace Your Preferences
    May 24, 2012 7:54 AM   in reply to chadtrent
    No, leaving it open is not going to make a difference.
    Doo you run Suitcase? I have a vague recollection that Suitcase causes this, and that Extensis has a patch for it.
    May 24, 2012 8:05 AM   in reply to chadtrent
    Other third-party plugins or font manager?
