aareiner
Trouble assigning TextFrame to Justification.Left
May 24, 2012 7:46 AM
Tags: #cs5 #script #text #javascript #scripting #illustrator_cs5 #textframes
Hello,
I need some help trouble shooting a script.
I am trying to flip the justification for all of a selected set of text frames. However, while most types of flipping work properly, the following does not
if(sel[i].story.textRange.justification == Justification.RIGHT){
         sel[i].story.textRange.justification = Justification.LEFT;
I would expect the justification for items that are Justification.RIGHT to switch to Justification.LEFT, but they remain as Justification.RIGHT
It does not fail, it just does not work as expected.
What is odd is that it seems to work correctly for the three other types of justification I am flipping in the same script. See below for the full script.
Any ideas what is causing this?
try
          // Check current document for textFrames.
          if ( app.documents.length < 1 ) {
                    alert ( "open a document with text objects and select them." );
          else {
                    docRef = app.activeDocument;
                    if ( docRef.textFrames.length < 1 ) {
                              alert ( "Select some text objects." );
                    //where text fames are selected swap the jusification
                    else {
                              sel = docRef.selection;
                              var sellen = sel.length;
                              for (var i=0;i<sellen ;i++)
                                        if(sel[i].typename == "TextFrame"){
                                                  if(sel[i].story.textRange.justification == Justification.LEFT){
                                                            sel[i].story.textRange.justification = Justification.RIGHT;
                                                  else if(sel[i].story.textRange.justification == Justification.RIGHT){
                                                  else if(sel[i].story.textRange.justification == Justification.FULLJUSTIFYLASTLINELEFT){
                                                            sel[i].story.textRange.justification = Justification.FULLJUSTIFYLASTLINERIGHT;
                                                  else if(sel[i].story.textRange.justification == Justification.FULLJUSTIFYLASTLINERIGHT){
                                                            sel[i].story.textRange.justification = Justification.FULLJUSTIFYLASTLINELEFT;
catch (e){
          alert("Script Failed!\n"+e);
  • John Hawkinson
    Jun 25, 2009
    May 24, 2012 7:56 AM   in reply to aareiner
    Well, have you tried printing out sel[i].story.textRange.justification before the if to make sure that it's the way you think it is? Use $.writeln().
    Does it work if you just run one line by hand and set the justification?
    May 24, 2012 9:08 AM   in reply to aareiner
    I get the same results as you?
    May 24, 2012 9:28 AM   in reply to Muppet Mark
    Me too.
    Feb 8, 2013 5:19 AM   in reply to aareiner
    I have experimented a bit this this and found out that once you resize the frame, it's possible to change justification from right to left. So right after creating the frame
    myTextFrame.resize(100.01,100.01)
    should help
    Feb 8, 2013 9:13 AM   in reply to Evgeny_Trefilov
    Give redraw a chance:
              else {
                        else {
              redraw()
    Feb 8, 2013 9:50 AM   in reply to pixxxel schubser
    this did not work on my system Win 7, CS5
    myTextFrame.resize(100.01,100.01);
    myTextFrame.story.textRange.justification = Justification.LEFT;
    this did not work either
    redraw()
    Feb 8, 2013 10:40 AM   in reply to CarlosCanto
    Too bad, because on Windows with CS3 it works
    app.activeDocument.selection[0].story.textRange.justification = Justification.LEFT;
    redraw()
    Feb 8, 2013 11:03 AM   in reply to CarlosCanto
    I'm using
    myTextFrame.resize(100.1,100.1);
    myTextFrame.textRange.paragraphAttributes.justification = Justification.LEFT;
    100.01 turns out to be not enough! sorry for this
    redraw(); doesn't work for me neither (CS5, OS X 10.8.2)
    and I don't see justification property on textRange(?) - but
    works as well. it seems that only resizing by X axis matters actually. indeed, frame can be resized back afterwards, it just takes to 'touch' the frame.
    Feb 8, 2013 11:41 AM   in reply to Evgeny_Trefilov
    great finding Evgeny!!! it works with
    pixxxel, I'll give it a try with CS4...it seems they broke it accidentally in that version then.
    Feb 8, 2013 11:59 AM   in reply to CarlosCanto
    @CarlosCanto,
    yes, I tried it now with CS5.1 on Win 7 and it doesn't work.
    But I found the reason for that:
    Your paragraphstyle is the normal paragraph style, right?
    And you can change to all justifications, but not the LEFT one?
    Make a new paragraph style with justification.FULLJUSTIFYLASTLINECENTER and apply it.
    Now your script can change to all justifications, but not back to the FULLJUSTIFYLASTLINECENTER !
    IMHO you can change to all, but in CS5 you can't go back to the justification, which is defined in the used paragraph style.
    Is this so?
    The solution should be: Use multiple paragraph styles in script
    (or Adobe wishform  --> bug or feature???)
    Feb 8, 2013 12:05 PM   in reply to pixxxel schubser
    interesting...then based on what you're saying, the safest thing to do is resize all text frames, align/justify, then resize back. I can live with that, I made an Align palette script a couple of weeks ago, I'll revise it to include these findings.
    in our eyes, it is a bug...Adobe will come up saying it is a feature.
    it seems to be easier to resize the text frames than to create paragraph styles and check each item for which one it has...
    Feb 8, 2013 12:28 PM   in reply to CarlosCanto
    I think it can be done like this:
    1) try to change justification
    2) check if it's changed
    3) if not, resize 100.1, then back to original, then apply justification again
    this is enough to do only once since the frame creation, next time justification will change fine
