Easy Question?
May 24, 2012 12:28 PM
I have a propbably easy question but one I can't seem to get to work right...
I have a web site with a footer at the bottom of the page...  In the footer on the left there is your typical Copyright line.  What I would like to do is add another Copyright line directly across from it on the same line just floated to the right side.  How do I accomplish this?  I'm always getting bumped down to the next line.
Here is the link to the unfinished test site...  It a pretty elementary site but well whatever...  Your help is much appreciated!
www.alt-end.net
    May 24, 2012 1:01 PM   in reply to Prodigy9
    This is how it's done using list items.
    Place each item in a list instead of a paragraph, display inline and remove the discs - then float the second item, as you said, to the right using an id.
    Hope it helps
    <style>
    .footer{width:980px; height:50px;}
    .footer li{
              display:inline;
              list-style:none;
    #footerMessageRight{
              float:right;
    </style>
    </head>
    <body>
    <div class="footer">
        <ul><li>Copyright 2012 Clean-A-Tank, Inc.  All rights reserved.</li>
          <li id="footerMessageRight">Copyright message</li>
          </ul>
        <!-- end .footer --></div>
    May 24, 2012 8:15 PM   in reply to Prodigy9
    Another method is to use two divs in the footer like this:
        <div id="left">
            <p>&copy; Left side: Copyright 2012 Clean-A-Tank, Inc.  All rights reserved.</p>
        </div>
        <div id="right">
            <p>&copy; Right side: Copyright 2012 Clean-A-Tank, Inc.  All rights reserved.</p>
        </div>
    And the related css like this:
    #left {
        width: 40%;
        float: left;
        color: black;
    #right {
        width: 40%;
        float: right;
        color: red;
    You just need to change 40% to 50% and you are done!
    May 24, 2012 8:55 PM   in reply to Prodigy9
    To be honest I'm really not sure why it wouldn't work. As long as the BG is set on the footer, then a list shouldn't make a difference - I don't think any way.
    Maybe the above solution will work better.
    May 24, 2012 9:35 PM   in reply to Prodigy9
    If you want to use the second method then you you need repeat-x and repeat-y for your background image.  I suggest use this css for your footer:
    .footer {
        padding: 20px;
        padding-bottom: 2px;
        position: relative;/* this gives IE6 hasLayout to properly clear */
        clear: both; /* this clear property forces the .container to understand where the columns end and contain them */
        color: #FFF;
       background-image: url('http://www.alt-end.net/images/background.png');
        font-size: 80%;
        background-color: #37A2E7;
        font-family: "Trebuchet MS", Arial, Helvetica, sans-serif;
        height: 50px;
    #left {
        width: 50%;
        float: left;
        color: black;
    #right {
        width: 50%;
        float: right;
        color: red;
    I justs tested this on a test page and it worls.  Please note, normally you should be using and Id for footer (Not a class) because there is only one footer on a page with its own styles.  However, don't change anything now except the css I have posted above.
    Go and have a nice sleep for now.
    Good luck.
    May 24, 2012 9:34 PM   in reply to Prodigy9
    I've just done a quick test in Dreamweaver and it works for me:
    <style>
    #footer{
              height:50px;
              width:980px;
              background-image:url(http://b9.sustatic.com/DxgV3l-zpvI5P5VrFdtePw);
              background-repeat:repeat-x;
    #left{
              float:left;
    #right{
              float:right;
    </style>
    </head>
    <body>
    <div id="footer">
    <div id="left">
    Copyright Left
    </div>
    <div id="right">
    More info Right
    </div>
    </div>
    I haven't hosted the file so you can't see, you'll have to take my word for it.
    If you use that code, and it doesn't work - it must have something to do with another element messing it up somewhere. Maybe see if FireBug shows anything up.
    That image is just a randomly hosted one, by the way - looks awesome imo.
