Set a date two days in the future
May 23, 2012 4:26 PM
Hi all
This code works fine to set a value if there is no value in form.MEETING (so I can insert the value into my db with sql):
<cfset isMEETINGNull = iif(len(trim(form.MEETING)) EQ 0, true, false)>
How can I set the value to a date two days from now if it is empty(instead of null as it is at the moment, seomthing like this?)
<cfset isMEETINGNull = DateFormat(DateAdd("d", +2, Now()), "MM/DD/YYYY")>
Thank you!
Message was edited due to google research possible answer
    May 23, 2012 6:03 PM   in reply to goodychurro1
    if (len(trim(form.meeting)) > 0
    theDate = dateAdd("d", 2, now();
    else
    theDate = something.
    But it's not that simple.  You might also have to ensure that form.meeting actually is a date and if so, that it meets whatever other criteria you have.  Finally, don't use dateformat in this situation.  It's a display function that returns a string.  You want to send a date object to your db.
    May 24, 2012 2:46 AM   in reply to goodychurro1
    Here is yet another suggestion. It includes validation.
    <cfset meetingDate = trim(form.meeting)>
    <cfif not isDate(meetingDate)>
    <cfset meetingDate = dateAdd("d", 2, now())>
    </cfif>
    The value to store in the database is then meetingDate.
    May 24, 2012 8:38 AM   in reply to goodychurro1
    I said, "The value to store in the database is then meetingDate". You yourself say, implicitly, at least, that there will be no null meetingDates. I therefore expected to see
    MEETING = <cfqueryparam cfsqltype="cf_sql_timestamp" value="#meetingDate#"/>
    May 24, 2012 9:15 AM   in reply to goodychurro1
    Whatever you have to do to change that field from varchar to timestamp, do it.
    May 24, 2012 9:29 AM   in reply to goodychurro1
    goodychurro1 wrote:
    Ok thanks BKBK, I changed it to meetingDate:
    No, you didn't!
    MEETING= <cfqueryparam cfsqltype="cf_sql_timestamp" value="#trim(form.MEETING)#"
    null="#meetingDate#" />
    I said nothing about nulls. Here it is again: MEETING = <cfqueryparam cfsqltype="cf_sql_timestamp" value="#meetingDate#"/>
    May 24, 2012 10:13 AM   in reply to goodychurro1
    I wouldn't go changing many things at once. That would lead to complexity. Start with your original code, and just tweak it a little, using the suggestions. For example
    <!--- UPDATE QUERY --->
    <cfif isDefined("form.UPDATEADDBTN")>
        <cfif FORM.ENTID GTE 1>
            <cfset isCOMMENTSNull = iif(len(trim(form.COMMENTS)) EQ 0, true, false)>
            <cfelse>
                <!--- Here, apply Dan's advice to convert from string to datetime object. Use, for example, parseDatetime, createdate or createdatetime --->
                <cfset meetingDate = parseDatetime(meetingDate)>
            </cfif>
        <CFQUERY name="updatecompany" datasource="salesdb">
            update COMPANY
            SET COMMENTS = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(form.COMMENTS)#" null="#isCOMMENTSNull#" />,
            MEETING = <cfqueryparam cfsqltype="cf_sql_timestamp" value="#meetingDate#" />
            WHERE ENTID = <cfqueryparam cfsqltype="cf_sql_integer" value="#FORM.ENTID#" />
        </CFQUERY>
    <cfelse>
    May 24, 2012 12:42 PM   in reply to goodychurro1
    Regarding, "
    I get this error in coldfusion?:
    Cannot convert the value of type class coldfusion.runtime.OleDateTime to a boolean"
    What is the line of code creating this error?
    May 24, 2012 11:01 PM   in reply to Dan Bracuk
    Dan Bracuk wrote:
    Regarding, "
    The error was caused by the attribute null="#meetingDate#". I had suggested that this attribute be left out altogether.
