Emaline83
Division Help
May 24, 2012 10:13 AM
I know this has been on here before, but I cannot seem to get any of the answers to work for me.  This is greatly due to the fact that I do not know anything about JavaScript.
I am working on a form for my company and it has been requested that I set up one of the fields to automatically equal the division of two other fields.  What I need is the simple notation or the custom calculation script to make this happen.
It needs to do the following calculation:
ACTUALPOINTS / POSSIBLESCORE = FINAL SCORE
"ACTUALPOINTS" is field 1.  "POSSIBLESCORE" is field 2.  "FINAL SCORE" should = field 1 divided by field 2.
Any help would be greatly appreciated!!!!
- JavaScript Dumb
  • George Johnson
    Aug 11, 2002
    May 24, 2012 10:40 AM   in reply to Emaline83
    Try this as the custom calculation script for the FINALSCORE field:
    (function () {
        // Get the field values, as numbers
        var v1 = +getField("ACTUALPOINTS").value;
        var v2 = +getField("POSSIBLESCORE").value;
        // Set this field's value
        if (v2 !== 0) {
            event.value = v1 / v2;
        } else {
            // Set to blank if denominator evaluates to zero
            event.value = "";
    Make sure the field calculation order is correct, and calculated fields should normally be set to read-only so the user is not able to interact with them.
    May 24, 2012 11:34 AM   in reply to Emaline83
    You can not divide by zero in JavaScript. So you have to test for a zero divisor before performing any division and properly control the execution of your JavaScript calculation.
  • George Johnson
    Aug 11, 2002
    May 24, 2012 12:57 PM   in reply to Emaline83
    You can add code to round the result. Exactly what would you like to do? The following can be used to round to the nearest hundredth. Just replace the other line with this one:
    event.value = util.printf("%.2f", v1 / v2);
  • George Johnson
    Aug 11, 2002
    May 24, 2012 1:06 PM   in reply to Emaline83
    For that you can do either of the following:
    event.value = util.printf("%.0f", v1 / v2);
    event.value = Math.round(v1 / v2);
  • George Johnson
    Aug 11, 2002
    May 24, 2012 1:12 PM   in reply to Emaline83
    Can you post the complete script you're using?
  • George Johnson
    Aug 11, 2002
    May 24, 2012 1:15 PM   in reply to Emaline83
    This is what I meant:
    (function () {
        if (v2 !== 0) {
        } else {
            event.value = "";
