I recently installed Lightroom 4.0 on my new Windows 7 Home Premiun SP1 (64 bit) computer and imported my Lightroom 3.6 catalog into a Lightroom 4 catalog.
I have two problems which may or may not be related.
First:
While working in the Library, adding key words, etc., Lightroom will suddenly report in the current photo "The file named "xxxx (either .mrw or .jpg)" is offline or missing". On viewing the folder listing in the left-hand pane, all of the folders display with a "?". They did not do so moments before.
Second:
My LR4 import path is C:\Users\Bain\Pictures\My LightRoom.
However, Lightroom is displaying the folders imported since the upgrade as if they are in the root of C:
When I view the folders in Windows Explorer they are displayed properly in the My Lightroom folder.
I'd apprecaite any suggestions or help in resolving these issues.
Bain
These two issues should not be related. In fact, the second is not an issue at all.
First, try right-clicking on one of the folders with a question mark. Choose "Find Missing Folder". This will allow you to point LR to where the folder is currently at. It will start by looking where LR thinks it is, but likely this is not the correct location.
Second, the folder listing isn't trying to say that the folders are on the root of C:. LR Only lists the folders which you have imported files from (unless you add folders). So it is just saying these file are on the C: drive. If you want to see the full path all the way back up to C:, right-click a folder and choose "Show Parent Folder". When the parent folder (in your case "My LightRoom") is shown, right-click and choose "Show Parent Folder" again, etc.
Thanks for your reply Brett
Let me clarify the issue of the Missing Folder.
1. The Lightroom 4 folder listing is normal
2. While working on a photo in a folder I receive the "The file named "xxxx (either .mrw or .jpg)" is offline or missing" message.
3. All of the folders in the folder listing are displayed with the question mark “?”.
4. This issue has occurred multiple times.
I worked in Lightroom until I was able to recreate the “offline or missing” message, and all the folders in My Lightroom displayed ‘?’
I followed your instructions, right-clicking on the folder the error occurred in, selecting Find Missing Folder and browsing the folder location, the folder view flickered, but all folders continued to display ‘?’.
While I was typing this, the folder listing in LR ‘refreshed’ and the folders no longer displayed ‘?’
As you can imagine this is extremely frustrating.
Bain
So, the folders that go missing are on C:, they just become disconnected from time to time and will instantly reconnect without issue? And when you import, you are also importing a copy to an external drive? Does this behavior have anything to do with whether or not the external drive is plugged in?
So, the folders that go missing are on C:, they just become disconnected from time to time and will instantly reconnect without issue?” Pretty much, except that I‘ve occasionally rebooted the computer and on restarting LR the folders are reconnected.
And when you import, you are also importing a copy to an external drive? Correct
Does this behavior have anything to do with whether or not the external drive is plugged in? I have confirmed that for all imports since upgrading, there are backup folders on the external drive, so it must have been connected.
Brett
I tried eliminating the “second copy” option, but it made no difference.
I did more detailed testing:
I select a folder, then an image
Go to the Develop module, edit the image
Return to the Library, the file is reported "off-line or missing" and all folders have a ?
If I select another folder all the folders are reconnected (or if I'm patient enough they will reconnect themselves)
This is repeatable.
Bain
