loader to reach 100% after loading several SWFs?
May 24, 2012 6:41 AM
How do I make the loader reach 100% when all a.swf, b.swfs, c.wfs and d.swf completes loading?
prototypeLDR.addListener(prototypeLO);
var swfsLoaded:Number=0;
var prototypeLDR:MovieClipLoader = new MovieClipLoader();
var prototypeLO:Object = {}; prototypeLDR.addListener(prototypeLO);
prototypeLO.onLoadInit = function(targetMC2:MovieClip){
          swfsLoaded++;
          if(swfsLoaded==4){
                    for (i=1; i<5; i++) {
                              _root.vest_mc["mcA"+i+"_mc"]._visible=false;
          _root.loaderBar2._visible = false;
          _root.borderX2._visible = false;
          _root.loaderBack2._visible = false;
          _root.gotoAndPlay(9);
prototypeLO.onLoadStart = function(targetMC2) {
          _root.loaderBar2._visible = true;
          _root.borderX2._visible = true;
          _root.loaderBack2._visible = true;
prototypeLO.onLoadProgress = function(targetMC2, lBytes, tBytes) {
          _root.loaderBar2._width = (lBytes/tBytes)*100;
          _root.percentDisplayZ.text = "% "+Math.round((lBytes/tBytes)*100);
btn.onRelease = function() {
                     prototypeLDR.loadClip("www.web.com/myfile/a.swf,_root.main1_mc);
                    prototypeLDR.loadClip("www.web.com/myfile/b.swf,_root.main2_mc);
                    prototypeLDR.loadClip("www.web.com/myfile/c.swf,_root.main3_mc);
                    prototypeLDR.loadClip("www.web.com/myfile/d.swf,_root.main4_mc);
//do more...
    May 24, 2012 8:31 AM   in reply to Ron Colmen
    You need a variable that is the sum of the total bytes of all your SWF and one that has the count of bytes loaded for use in instead of lBytes and Tbytes
    May 24, 2012 8:29 AM   in reply to Ron Colmen
    One approach would be to make the bar width total change 25% for each file.
    May 24, 2012 11:50 AM   in reply to Ron Colmen
    bytes_loaded=Math.round(loaderA.getBytesLoaded()+loaderB.getBytesLoade d()+loaderC.getBytesLoaded()+loaderD.getBytesLoaded());
    bytes_total=Math.round(loaderA.getBytesTotal()+loaderB.getBytesTotal() +loaderC.getBytesTotal()+loaderD.getBytesTotal());
    May 24, 2012 12:26 PM   in reply to Ron Colmen
    Only if you make it be invisible 4 times.  I wouldn't.
    May 24, 2012 1:45 PM   in reply to Ron Colmen
    Just move the lines that make it invisible outside of any function so that it is only invisible at the start.  As soon as it is made visible the first time it will stay visible.
    May 24, 2012 2:36 PM   in reply to Ron Colmen
    You can add a counter
    var counter:int=0;
             if(++counter>=4){
