Working on Encore Cs3 I've got a very complicated menu that has no errors found within it yet when it comes to the build and burn halfway through it fails and a dialogue box come up saying 'Unexpected files were found in the AUDIO_TS or VIDEO_TS directory'. I have searched every part of the project and can't find what is causing the error. Has anyone else had this happen? Recommendations?
Jo
MAUNATOY - Please do not SHOUT (turn your caps lock off)
More information needed for someone to help... click these links and provided the requested information
Hi Stan.
As far as Encore goes, you are correct here but the DVD spec does not limit you to 99 timelines.
What is does is limits the number of VTS you can have to 99, with up to 99 clips per VTS.
(I am not certain if you are actually limited to 99 clips across a maximum of 99 VTS though - will have to check that one out)
It's Encore's habit of automatically turning every timeline into a separate VTS that creates this issue.
Workaround? Dare I say it, but perhaps multiple clips in a timeline might help. They would need to have the same aspect ratio and audio streams to keep in spec though.
