jwong_ser
How to customize the display and look and feel of the results page message?
Apr 17, 2012 4:36 PM
Tags: #results_page
Hi all
I've searched everywhere but cannot change its appearance (Captivate 5.5). It looks ugly like that:
    Apr 17, 2012 5:27 PM   in reply to jwong_ser
    jwong_ser,
    I think you've come to the right place for help, but you haven't given anyone reading this post anything to go on...what do you want? Try and give as much detail as you can...what is the image you supplied? How do you want to change it...or, is the image you supplied what you want it to look like?
    There are some really knowledgeable folks on this forum and they've help me with some fairly complex issues...help them understand your problem and I'm sure you'll get an answer.
    Apr 17, 2012 8:36 PM   in reply to Mr5strings
    My guess is that the original poster was referring to the long string of words in the Quiz Result message that is currently stretching across the page.
    The bad news is that you have no way to force this text to wrap based on the size of the Review Area on the Quiz Results page.  This issue has been flagged many times on this forum.  Please feel welcome to add your name to the people that have logged an enhancement request to have more formatting options for Quiz Result messages.
    In the mean time, I would suggest you reword your somewhat longwinded result message to whittle it down to something concise that allows you to use decent sized text on a single line.  Maybe something like: "Sorry. You were not successful this time.  Please try again."
    Apr 18, 2012 12:40 AM   in reply to jwong_ser
    If you do not mind a little bit of work, it is perfectly possible to create your own Review messages (text captions) for the score slide as Text Captions and trigger an advanced action on Entering the score slide to show the proper text caption based on the value of the Quizzing System variable cpQuizInfoPassFail (or another one). You could even create more text captions, not only a Pass/Fail but for the different scores or percentages but then you'll need to use another variable.
    If you want to try that, could offer you the workflow. But feel free not to bother about my answer.
    Lilybiri
    Apr 22, 2012 7:20 PM   in reply to jwong_ser
    Be aware though, that if you build your own Quiz Results page, you do NOT have the option on that page to include buttons for Retake Quiz or Review Quiz.  You would need to still have a real Quiz Results slide present for those buttons to trigger the correct functions in Captivate.
    Apr 23, 2012 12:37 AM   in reply to RodWard
    Rod,
    I was not talking about creating a custom Quiz results slide, but about customizing the Review message on the default Results page. In that case you can have all the functionalities like Review, Retake but have to be careful to keep the original Review field.
    Lieve
    Apr 23, 2012 1:03 AM   in reply to Lilybiri
    OK.  My apologies for misunderstanding.
    May 24, 2012 7:20 PM   in reply to jwong_ser
    This question is not possible to answer definitively without understanding the way you've set up your Advanced Actions and variables for this project file.
    It sounds like maybe your interaction design hasn't allowed for the case where users might come back to this results slide later in the session.  The Retake Quiz button will jump the user back to the slide containing the very first scored object in the project and will revert the quiz score back to zero again for another attempt.  However, this doesn't mean that it will automatically set all of your custom variables back to their original default values again as well.  The function triggered by Retake Quiz to reset scoring is an internal function that only looks at scored objects, not at other score-related variables and Advanced Actions you might have set up to achieve the effect you wanted.
    So you may need to build in some more logic to cover situations where a user enters slides on their second attempt.  You can set Conditional Advanced Actions to look for the System Variable cpQuizInfoAttempts and if it is NOT set to 0 then execute some series of actions to clear or reset your custom variables.
    May 24, 2012 11:59 PM   in reply to jwong_ser
    Please, where did you post that question? Normally I get a warning about each comment on my blog, and try to answer ASAP, but cannot remember this one. Could be my side of course, because have been little bit too busy these last weeks. If you could post the link, I could perhaps repair this??
    If you posted the comment on one of the articles I wrote with the Adobe Publishing AIR app, I do not get any warning about that. It is one of the reasons I abandoned to use that application, it is very cumbersome to have to open each article regularly to see if someone asked anything.
    Lilybiri
    May 28, 2012 2:29 AM   in reply to jwong_ser
    I can reply, but do not get any warnings when someone posts a question over there.
    Which version of CP are you using? The video was created for 5.0 and in 5.5 some Quizzing system variables are updated in a better way. However they are still read only, so you cannot 'reset' a system variable if it is not done by the quiz functionalities. One example: if the user clicks on the Retake button on the Score slide, the system variables cpInfoPercentage and cpQuizInfoPointsscored are reset to 0, and the cpQuizInfoAttempts is incremented.
    Bit busy for the moment, but if you could explain clearly what you want, and perhaps let me have a look at your project, I will try to figure it out. The condition is of course that I can blog about it.
    On my blog I have some examples of custom questions where I allow Retake/Review, think they are all with the enhanced widgets by Jim Leichliter, in the soap about Widgets and Custom Questions.
    Lilybiri
    May 29, 2012 6:27 AM   in reply to jwong_ser
    Did you attach the Advanced action that shows the feedback to the On Enter event? How do you make Cp know that it is a Retake, not a Review mode?
    You could post the file on acrobat.com (free - log in with your Adobe ID), share it and publish it and send me the link by private message. Dropbox or something similar is also OK for me.
    Lieve
    May 31, 2012 12:02 AM   in reply to jwong_ser
    Captivate has a system variable that tracks the number of attempts that a user has made on the Quiz (cpQuizInfoAttempts).  So you can set up On Slide Enter events with Conditional Advanced Actions to watch this variable and execute actions of your choosing if the variable is found to be equal to 1 or 2 etc.
    However, you cannot attach a conditional action to the Retake Quiz button itself, nor is there any variable available to you that will tell you that the user is currently in the middle of performing another attempt.  The same is true of the Review Quiz button. It does one thing only and there is no variable to tell you that the user is currently in Review Mode.
    This is an area of need in Captivate that will hopefully be addressed in future versions.
    May 31, 2012 1:27 AM   in reply to jwong_ser
    Sorry, have been too busy and promised so much to users.
    I just downloaded your file and will have a look when I'm finished with the student consultations,
    Lieve
    First corrections: the advanced action testscoreessai (vous utilisez la version française ):
    • you  miss an action if the score is exactly 10, so I changed the Failed criterion to 'cpQuizInfoPointsscored lesser or equal to 10'
    • for the THEN region you have to add two Hide statements for the TC not to be displayed, example for Failed:
      • Show Text_Caption_Failed
      • Hide Text_Caption_Middle
      • Hide Text_Caption_Passed
    The reason is that once you make a caption visible it remains visible. It is perhaps not really necessary for the Excellent decision, didn't figure out if you allow Review then??? But to be sure I did hide there as well.
    Now have to search what you want more. Or can you post that again? Have another project and a student (Spanish this time) waiting.
    Jun 1, 2012 12:51 AM   in reply to jwong_ser
    Your deduction is not correct, perhaps I explained not well enough. The text captions will never appear automatically, provided of course that they were initially invisible (were they?). But one of my tips in the blog post http://lilybiri.posterous.com/look-before-you-leap-in-advanced-actions is to consider all possible situations and sequences that can happen when the student is taking the course. In this case: if the student first fails, the Fail caption is made visible and will remain visible. If on his second attempt he will get a middle score, you do have not only to show the Middle caption, but to make the already visible Fail caption invisible again. And if on his third attempt he gets an Excellent you'll have to make the Middle caption invisible. But this is not the only possible sequence: he could have first a Middle and then a Fail score, correct? That is the reason why I hide both Fail and Middle invisible for the Excellent decision. To simplify this process: always hide everything that you do not want to appear in a situation, even though it may already be invisible.
    Lilybiri
    Jun 2, 2012 9:49 AM   in reply to jwong_ser
    There must be something else awry, indeed, but cannot judge without seeing the project. No, I didn't try to give that message, but you have to understand the logics of Captivate. If you screen all possible situations you can perhaps limit the number of statements, do not need all the Hides. But it is never wrong to hide an object that you do not want to appear in that specific situation even though it is already invisible. So for editing reasons (easier to change the duplicate actions) I sometimes accept superfluous statements.
    Lilybiri
