gopi k
Targeting multiple platform
May 24, 2012 1:11 AM
Tags: #adobe #ios #swf #ipad #flash_cs5
hi
              can i create a application targrtting muliple platform like iphone,ipad,mobile,web using flash proffesional tool? if it possible share some idea and get back soon its urgent
    May 24, 2012 1:55 PM   in reply to gopi k
    You can create a proyect and compile a stand alone applications with AIR to Mac, PC, GNU/Linux, iOS and Android
    or Can create a web aplication (like Farm Ville) can access this Mac, PC, GNU/Linux and Android
    May 24, 2012 9:19 PM   in reply to gopi k
    Yes!
    When you open Flash select one of the options for each platform.
    The main difference when exporting to iOS/Android is you DON'T go to file>Export. You click the spanner icon in the publish settings (properties), then click publish at the bottom.
    Charles
    May 25, 2012 7:41 AM   in reply to Charles Bannister
    Beware the way you code it must stay within the abilities of the devices you wish to code for. Not everything Flash does is supported on every platform. Devices are most limited.
    Pre-plan your assets (images/video/audio/etc) in a format suitable for all your targets and keep the quality and resolution as high as possible to start so your desktop version will look and work great. Then be prepared to reduce the quality and have code capable of handling either a new layout/form factor as the screen resolution goes down for devices.
    Be prepared to work with some variable hardware. Androids especially have all sorts of different resolution screens and varying hardware support. Just plan plan plan.. Most of your codebase will be re-usable if you continue to think and code like this.
    Jun 2, 2012 7:43 PM   in reply to gopi k
    If you're good please mark it answered (correct). good luck!
