Premiere Pro CS6 (6.0.1) update available
May 24, 2012 10:48 PM
After Effects CS6 and Premiere Pro CS6 bug-fix updates are available, with performance improvements and some new features. Details here: http://adobe.ly/lsrkmJ
Install the updates and let us know how they work for you. They should solve a lot of problems.
Branched to a new discussion.
    May 25, 2012 5:32 AM   in reply to Todd_Kopriva
    Thanks Adobe great support!!!!
    May 25, 2012 6:23 AM   in reply to Todd_Kopriva
    Thanks, Todd!
    May 25, 2012 6:53 AM   in reply to Todd_Kopriva
    Still don't see the ability on Multi-Camera Monitor to drop the frame rate (like you can on the source and reference windows) to allow usage on less powerfull machines
    May 25, 2012 7:55 AM   in reply to Todd_Kopriva
    I installed the update and Norton blocked a file. (that has never happened before)  Once I releaseed the file from Norton, Premiere still wouldn't load.
    I had to reinstall the whole program...now Premiere opens up again.
    As a result, I am afraid to allow the update on my other computer.
    Why is the update setting off Norton anti-virus?   This has never happened in the past.
    May 25, 2012 8:17 AM   in reply to Todd_Kopriva
    Keep 'em coming, Adobe.   I see nothing in the "fixed bugs" list about the mightykilt error dialog, the titler and export windows reverting to default state constantly, the blank VST audio plugs GUI, and most importantly, the Info pane not updating while trim functions are being performed.
    It's a good start.
    May 25, 2012 8:43 AM   in reply to Todd_Kopriva
    I am confused about the 5.03 update for windows which shows numerous fixes. However 5.03 has been out for quite some time. Should it be 5.04 as with the Mac?
    May 25, 2012 8:45 AM   in reply to sportsguy7
    IIRC, 5.0.4 was a Mac-only update. 5.0.3 was the last PC/Mac update.
    Good luck,
    Hunt
    May 25, 2012 8:53 AM   in reply to Todd_Kopriva
    When I try to start Premiere CS6.01 the loading stops on
    "ExporterQuickTimeHost.prm" for 3-4 Min. now (since the Update)
    after this time, the Program works normal.
    Has anybody an idea about this ???
    Regards
    Matthias
    May 25, 2012 8:58 AM   in reply to Todd_Kopriva
    Can anybody confirm if the HDV capture naming clips bug has been fixed?
    May 25, 2012 9:06 AM   in reply to schma29
    I had to reinstall the CS6 suite in order to get Premiere to not stall, (and not open at all) on the "ExporterQuicktimeHost.prm".
    The program opened up fine before the update.
    May 25, 2012 9:07 AM   in reply to Todd_Kopriva
    Restarting the computer didn't help at all.  I had to reinstall the suite in order for Premiere to open up.
    May 25, 2012 9:15 AM   in reply to Todd_Kopriva
    Damn Todd, you guys have really been busting humps with this CS6 release.  Outstanding work!
    May 25, 2012 11:44 AM   in reply to Todd_Kopriva
    Todd, a lot of bugs was fixed, maybe it's time to modify editing behaviours, time to think about editors which get used to work with mouse, so called mouse-fans (CS5.5 and older) just by adding a switch near the Snap switch called Selectable Edit Points.
    Mode 1: Edit Point(s) are Selectable (CS6)
    Mode 2: Edit Point is Not Selectable (Premiere 1.0 - 6.5c, Premiere Pro CS1 - CS5.5)
    also adding a checkbox in Preferences > Trim:
        Allow Selection tool to select Edit Points inside a selection of multiple Clips
    after the switch
        Allow Selection tool to choose Roll and Ripple trims without modifier key
    details in a Discussion: http://forums.adobe.com/message/4438638
    May 25, 2012 11:47 AM   in reply to Steven Pribilinskiy
    Steven,
    If you haven't already made them, these are feature requests: http://www.adobe.com/go/wish
    May 25, 2012 2:12 PM   in reply to Kevin Monahan
    Kevin, you may notice that in most of my posts there's a
    Feature Request/Bug Report Form
      ******BUG******
    section
    Link: http://www.adobe.com/go/wish
    and there's a link to http://www.adobe.com/go/wish
    The thing is that you will not receive feedback from the Feature Request Form
    May 27, 2012 11:52 AM   in reply to Todd_Kopriva
    Has the AVCHD bug been fixed with this release? http://forums.adobe.com/message/4437674
    May 27, 2012 4:02 PM   in reply to Todd_Kopriva
    thanks for the lighting update adobe.
    however, even with the update i'm still getting the delay in monitor playback
    via my sdi monitor via my blackmagic decklink hd extreme card (macpro, lion 10.7.4)
    any advice or possible fixes ?
    thanks
    jeff
    May 27, 2012 4:04 PM   in reply to alibipictures
    Do you have the most recent drivers for your BM Decklink card installed?
    May 27, 2012 5:02 PM   in reply to lasvideo
    good call lasvideo
    just did the latest update 9.5.2, however  it hasn't fixed it
    May 27, 2012 5:18 PM   in reply to alibipictures
    I fixed my problem by uninstalling CS6 and CS5.5.  I then ran the Adobe suite Cleaner Tool.  I then disabled my Norton 360 program.  I then reinstalled CS5.5 and CS6.
    All is well, Premiere loads fine, and all seems to be working normally.   So FYI...disable your Norton 360 program before accepting any updates from Adobe.
    At this point I am afraid to turn the Norton program back on...sad, but the files in the Adobe update come across as "suspious".
    Agian, I tried every other way to fix this, but this solution worked.  Deactivate Adobe, Uninstall, Use the Adobe Cleaner program, reinstall with the Norton program disabled.
    Big hassle to say the least!  But Premiere is working normally now.
    I hope this helps others who are also using the Norton 360 Anti virus program.  (I still have no idea why the Adobe update set it off)
    May 27, 2012 5:22 PM   in reply to CAOLSEN
    I wouldn't bother with Norton to be honest but great that you have found a solution
    May 27, 2012 5:29 PM   in reply to Keano66
    i'm on a mac and not running norton.
    i will use the uninstall/reinstall option as last resort
    hoping to find another solution
