Hello
I need help to complete a script.
I must regularly convert. Have to. Ps
I would like to make a batch on a folder.
I tried recording an action script illustrator but always select the default print.
I find this script on the forum
But I still have the same problem it selects the default printer, how to force it to use the PostScript printer
Thank you
var docs = app.documents;
var docCount = docs.length;
// if there are opened documents, print them, otherwise ask for a folder to batch print
if (docCount>0) {
alert(docCount);
printOpenDocs(docs);
else {
var folder = Folder.selectDialog("Select Source Folder..."); // select folder
printFolder(folder);
// Prints and closes each open document
function printOpenDocs(docs) {
for (j=docCount-1; j>=0; j--) {
var jdoc = docs[j];
jdoc.print(options);
jdoc.close(SaveOptions.
DONOTSAVECHANGES);
function printFolder(folder) {
if (folder==null) {
alert("Good Bye");
else {
var files = folder.getFiles ("*.ai"); // get files
var fileCount = files.length; // count them
if (fileCount>0) {
for (i=0; i<fileCount; i++) {
var idoc = app.open(files[i]);
idoc.print();
idoc.close();
else {
alert("There are no Illustrator files in this folder.");
This should give you a decent enough start…
#target illustrator
printPostScript();
function printPostScript() {
app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
var docPath, docs, inFolder, opts, psPath;
jobOpts = new PrintJobOptions();
opts = new PrintOptions();
opts.printPreset = 'PostScript';
opts.jobOptions = jobOpts;
if ( app.documents.length > 0 ) {
} else {
inFolder = Folder.selectDialog( 'Select Source Folder...' );
if ( inFolder != null ) {
docs = inFolder.getFiles( '*.ai' );
for ( i = docs.length-1; i >= 0; i-- ) {
if ( docs[i] instanceof File ) {
app.open( docs[i] );
} else {
app.activeDocument = docs[i];
docPath = decodeURI( app.activeDocument.fullName );
psPath = docPath.replace( /.ai$/, '.ps' );
jobOpts.file = File( psPath );
app.activeDocument.print( opts );
app.activeDocument.close( SaveOptions.DONOTSAVECHANGES );
app.userInteractionLevel = UserInteractionLevel.DISPLAYALERTS;
