fanglinyong
How to solve this equation?
May 24, 2012 6:37 AM
can anybody help me, solve this problem in as3 ?
x+y+z=8000;
0.17*x + 0.35*y +0.08*z =960
thanks very much!!!
    May 24, 2012 8:25 AM   in reply to fanglinyong
    I kinda wanna lean on rusty learning and say it can't be solved... three unknowns requires three equations.
    As far as solving it with AS3, what do you mean?
    May 25, 2012 1:06 AM   in reply to fanglinyong
    AS3 for the above is
    for (var i:int = 0; i < 33; i++)
              for (var j:int = 0; j < 12; j++)
                        for (var k:int = 0; k < 300; k += 3)
                                  if ((i + j + k == 100) && (3*i + 8*j + k/3) == 100)
                                            trace("x=", i, ", y=", j, ", z=", k);
    trace("done");
    note 3 unknowns with 2 equations gives 2 solutions
    May 25, 2012 3:42 AM   in reply to fanglinyong
    this gives a little more explanation, although doesn't actually complete for me there are too many permitations
    you are also going to have to worry about the number representation issue using floating points numbers
    it might be better to convert the second equations to something equivalent which uses ints
    package
              import flash.display.Sprite;
              public class Main extends Sprite
                        //x+y+z=8000;
                        //0.17 * x + 0.35 * y +0.08 * z = 960
                        public function Main()
                                  // consider each equation in the form a.x + b.y + c.z = d
                                  // we have 3 unknowns x, y, z so we need 3 nested for loops to run over all possibilities
                                  // then the maximum value x can be is d/a
                                  // maximum y = d/b
                                  // maximum z = d/c
                                  // now if we have 2 equations we need to take the maximum for each known from either equation
                                  // so in your case with maximum x is the maximum of 8000/1 and 960/0.17 =
                                  // maximum y is the maximum of 8000/1 and 960/0.35
                                  // maximum z is the maximum of 8000/1 and 960/0.08
                                  // all these maximums should be rounded down to the nearest integer
                                  //max x = 8000
                                  //max y = 8000
                                  //max z = 12000
                                  //we use these maximum values for the nested for loop limits
                                  var maxX:int = Math.max(8000 / 1, 960 / 0.17);
                                  var maxY:int = Math.max(8000 / 1, 960 / 0.35);
                                  var maxZ:int = Math.max(8000 / 1, 960 / 0.08);
                                  trace("max values: ", maxX, maxY, maxZ);
                                  for (var i:int = 0; i < maxX; i++)
                                            for (var j:int = 0; j < maxY; j++)
                                                      for (var k:int = 0; k < maxZ; k++)
        // this if statement is a representation of if the values for x, y and z we are trying
        // actually solve the equations
        // so in your case use the following
        if ((i + j + k == 8000) && (0.17*i + 0.35*j + 0.08*k) == 960)
                                  trace("done");
