last time sinious help to me.
i using that script with little changes.
if i add "Kbps" in that bandwidthHandler my tests failing.
if i remove 'Kbps' that working good.
function bandwidthHandler(e:AppEvent):void
downSpeeds.text = e.params.bandWidth +"Kbps";
downTest();
function downTest()
if (Number(downSpeeds.text) >= 512)
Pass.visible = true;
Fail.visible = false;
else
Pass.visible = false;
Fail.visible = true;
Your problem is adding a string to a number and trying to compare it as a number...
Try passing the e.params.bandWidth as an argument to the downTest function instead of using the textfield.
downTest(e.params.bandWidth);
function downTest(dnSpeeds:Number)
if (dnSpeeds >= 512)
else
and one more same issue pls..
this is already string so ......
upSpeeds.text = String( int(( ( uploadFile.size/tm.currentCount ) / 1024 ) * 8 )) + " Kbps";
function uploadTest()
if (Number(upSpeeds.text) >= 256)
upPass.visible = true;
upFail.visible = false;
else
upPass.visible = false;
upFail.visible = true;
yaa i tried night, finally i got it.
Thanky you for ....
var upSpeeds:int;
upSpeeds= (( ( uploadFile.size/tm.currentCount ) / 1024 ) * 8 );
upSpeeds.text = upSpeeds + " Kbps";
if (Number(upSpeeds) >= 256)
else
