Pierre-RAFFA
Apply [None] Color in TextFrame contents
May 25, 2012 6:20 AM
Hi all,
Is it possible to apply [None] Swatch/Color to a TextFrame contents ?
I currently use this:
var vNoneColor = app.swatches.itemByName("None");
for (var iText=0; iText < vTextFrame.texts.length ; iText++)
        var vText = vTextFrame.texts.item(iText);
        alert(vText.contents);
        vText.fillColor = vNoneColor
or maybe create my own Color but it's not possible to change transparency.
Thanks.
Pierre RAFFA.
    May 25, 2012 6:32 AM   in reply to Pierre-RAFFA
    Pierre,
    Try this:
    vText.fillColor = null;
    or
    vText.fillColor = NothingEnum.NOTHING;
    Hope that helps.
    Marijan (tomaxxi)
    http://tomaxxi.com
    May 25, 2012 6:43 AM   in reply to Pierre-RAFFA
    Yes, you are right. I didn't tested it.
    This works:
    vText.fillColor = app.activeDocument.swatches.item("None");
    Marijan (tomaxxi)
    May 25, 2012 8:53 AM   in reply to Pierre-RAFFA
    You should really use the locale independent name:
    var noColor = doc.swatches.itemByName("$ID/kNoneName");
    May 31, 2012 2:59 PM   in reply to Harbs.
    Hi Harbs and Marijan,
    Just curious, any reason not to use vText.fillColor = "$ID/kNoneName"; without the "preamble" doc.swatches.itemByName ?
    May 31, 2012 11:36 PM   in reply to Trevorׅ
    No. Probably not.
    I tend to use object references rather than strings, but it should work fine here.
    Jun 1, 2012 1:01 AM   in reply to Harbs.
    @Harbs – in my German InDesign " fillColor = "None" " does work as expected. Are there other localized versions of InDesign where this does not work?
    So this does the job:
    myTextFrame.texts[0].fillColor = "None";
    Uwe
    Jun 1, 2012 1:10 AM   in reply to Laubender
    I don't know about other languages, but locale independent strings are always safer...
    Jun 1, 2012 2:31 AM   in reply to Harbs.
    Harbs,
    Surprisingly, "$ID/kNoneName" doesn't work for Object Styles.
    Usually, I do it like this:
    var _noneObjStyle = app.activeDocument.objectStyles.item(0);
    Marijan (tomaxxi)
    Jun 1, 2012 5:42 AM   in reply to Marijan Tompa
    Yes. For styles I do it that way. Swatches can be moved around, so the first is not always "[None]"...
    Jun 1, 2012 9:03 AM   in reply to Harbs.
    I'm afraid this is no correct in the specific case of swatches—and the code above should not work in non-EN languages.
    Whatever the locale the None swatch has always the internal name "None"—even if it is localized in the Swatch panel as [None], [Sans], [Ohne], etc. (depending on the locale). This fact is very specific to the Swatches collection, which basically uses None, Black, Paper and Registration as unique reserved names in a locale-independent way. (By contrast, the reserved names of the styles collection, including None, are locale-dependent!)
    As a consequence, the regular way to point out to the None swatch in any language, is:
    var noneSwatch = myDoc.swatches.itemByName('None');
    alert( noneSwatch.isValid ); // should always be true
    alert( noneSwatch.name ); // should always be"None"
    Likewise, the shortcut to apply this swatch, in any language, is:
    myObj.fillColor = "None";
    whereas myObj.fillColor = "$ID/kNoneName" will fail in non-EN locales because this actually means:
    myObj.fillColor = app.translateKeyString("$ID/kNoneName");
    i. e.:
    myObj.fillColor = "Ohne"; // in German => error
    myObj.fillColor = "Sans"; // in French => error
    By contrast, name-based access to special object styles can be done locale-dependently, and should be done locale-independently:
    var noneStyle = myDoc.objectStyles.itemByName('$ID/[None]'); // OK
    Marc
