comma(,) after 3 digits
Engaged ,
May 25, 2012 May 25, 2012
i trying ot add comma(,) after 3 digits to my result value.
but result first time is good, and 2nd time is result changed (not correct result value)
my code:
var reg:RegExp = /\d\d\d$/g;
var a:Array = new Array();
var res:String ='';
var dnSpeeds:String;
  dnSpeeds = e.params.bandWidth;
  downSpeeds.text = dnSpeeds + " Kbps";
  downTest();
while (dnSpeeds.length > 3){
          a.push(','+dnSpeeds.match(reg));
          dnSpeeds = dnSpeeds.replace(reg,'');
          for (var i:int = a.length; i > 0; i--){
          res = res+a[i-1];
          res = dnSpeeds+res;
          trace(res);
function downTest()
if (Number(dnSpeeds) >= 512)
  Pass.visible = true;
  Fail.visible = false;
else{
  Pass.visible = false;
  Fail.visible = true;
ActionScript
1.4K
Community Expert , May 25, 2012 May 25, 2012
search for "number formatting flash as3" to find formatting that does what you want.  for example,
http://stackoverflow.com/questions/721304/insert-commas-into-number-string
Engaged ,
yaa i tried this example. working
thank you guys,
May 26, 2012 May 26, 2012
you're welcome.
Enthusiast ,
I used this function, I found somewhere that I can not remember
function addCommasToNumber(number:Number):String
    var negNum:String = "";
    if (number<0)
        negNum = "-";
        number = Math.abs(number);
    var num:String = String(number);
    var results:Array = num.split(/\./);
    num = results[0];
    if (num.length > 3)
        var mod:Number = num.length % 3;
        var output:String = num.substr(0,mod);
        for (var i:Number = mod; i<num.length; i += 3)
            output += ((mod == 0 && i == 0) ? "" : ",")+num.substr(i, 3);
        if (results.length > 1)
            if (results[1].length == 1)
                return negNum+output+"."+results[1]+"0";
            else
                return negNum+output+"."+results[1];
        else
            return negNum+output;
            return negNum+num+"."+results[1]+"0";
        else
            return negNum+num+"."+results[1];
    else
        return negNum+num;
