comma(,) after 3 digits
May 25, 2012 6:17 AM
i trying ot add comma(,) after 3 digits to my result value.
but result first time is good, and 2nd time is result changed (not correct result value)
my code:
var reg:RegExp = /\d\d\d$/g;
var a:Array = new Array();
var res:String ='';
var dnSpeeds:String;
  dnSpeeds = e.params.bandWidth;
  downSpeeds.text = dnSpeeds + " Kbps";
  downTest();
 while (dnSpeeds.length > 3){
          a.push(','+dnSpeeds.match(reg));
          dnSpeeds = dnSpeeds.replace(reg,'');
          for (var i:int = a.length; i > 0; i--){
          res = res+a[i-1];
          res = dnSpeeds+res;
          trace(res);
function downTest()
if (Number(dnSpeeds) >= 512)
  Pass.visible = true;
  Fail.visible = false;
else{
  Pass.visible = false;
  Fail.visible = true;
  • kglad
    Jul 21, 2002
    May 25, 2012 8:27 AM   in reply to Venkom
    search for "number formatting flash as3" to find formatting that does what you want.  for example,
    http://stackoverflow.com/questions/721304/insert-commas-into-number-st ring
    May 25, 2012 8:33 AM   in reply to Venkom
    I used this function, I found somewhere that I can not remember
    function addCommasToNumber(number:Number):String
        var negNum:String = "";
        if (number<0)
            negNum = "-";
            number = Math.abs(number);
        var num:String = String(number);
        var results:Array = num.split(/\./);
        num = results[0];
        if (num.length > 3)
            var mod:Number = num.length % 3;
            var output:String = num.substr(0,mod);
            for (var i:Number = mod; i<num.length; i += 3)
                output += ((mod == 0 && i == 0) ? "" : ",")+num.substr(i, 3);
            if (results.length > 1)
                if (results[1].length == 1)
                    return negNum+output+"."+results[1]+"0";
                else
                    return negNum+output+"."+results[1];
            else
                return negNum+output;
                return negNum+num+"."+results[1]+"0";
            else
                return negNum+num+"."+results[1];
        else
            return negNum+num;
  • kglad
    Jul 21, 2002
    May 26, 2012 7:35 AM   in reply to Venkom
    you're welcome.
