I couldn't find this anywhere in the help. The only time it mentioned linking to a bookmark from a TOC was if you used the feature to autocreate your TOC.
I think I figured out how to do it, but wanted to run it by the forum to see if this is right.
Is this how it's done?
For example, if your topic appears as Entering_a_New_Customer.htm and the bookmark is called address, you'd add #address to the end of the filename. That gives you a link of Entering_a_New_Customer.htm#address
Is there a different way to do it? This way requires two steps and requires you to know the name of the bookmark; you can't navigate to it.
Hi there
It should be simpler than that.
See if the screencast linked below helps.
Cheers... Rick
Hi there
Cheers... Rick
I knew it had to be simpler! It makes sense now that I know how to do it.
