Illustrator 9.0 - how do I remove arrowhead from a line?
May 25, 2012 11:36 AM
Please / Thanks:  How can I remove an existing arrowhead from a line?     If I delete the line/arrowhead, remove any arrowhead designation in "Add Arrowheads" dialog and draw a different line, the arrowhead still appears.  Also, is Is there a way to change the line weight, thinner, without changing the size of the existing arrowheads OR change the size of the arrowhead without affecting the line?    Appreciate.
    May 25, 2012 11:44 AM   in reply to TheHikermann
    Hikermann,
    In the Appearance palette, you may toggle between New Art Maintains/Has Basic Appearance.
    The size of the Arrowhead follows the Stroke Weight. You should be able to Object>Expand Appearance, thus making the arrowhead an independent object (in the same Group unless ungrouped) and then change the now independent line.
    May 25, 2012 12:14 PM   in reply to TheHikermann
    You are welcome, Hikermann.
