BEA Marcom
PDF export vanishes when finished
May 25, 2012 12:15 PM
Tags: #cs5 #error #pdf #mac #export #indesign #indesign_cs5
I'm having a problem that just started today where every time I try to export a PDF of a document, the PDF disappears as soon as the export finishes.
I've tried multiple PDF export settings and have restarted the program too.
I'm on Mac OS X 10.6.8, using InDesign 7.0.4
    May 25, 2012 12:21 PM   in reply to BEA Marcom
    You explicitly say “the PDF file disappears as soon as the export finishes.” How do you know that there ever was a PDF file created. What you are describing sounds like the export is failing prior to its completion and if a partial PDF file was created, it is being deleted as part of the clean-up of the failed export. Any error messages that you can see?
    Have you tried exporting from a new, very simple InDesign document?
              - Dov
    May 25, 2012 12:40 PM   in reply to BEA Marcom
    Is this isolated to a single file, or does it happen if you make another new file?
    May 25, 2012 12:55 PM   in reply to BEA Marcom
    Does it work with NEW file that does not contain elements from this one?
