tallguyjim72
Adaptive wide angle causing wavy lines even though marked as straight and vertical?
May 24, 2012 12:28 AM
I have the beta installed but I also installed the trial of CS6 on another computer.. Both do the exact same thing with the Adaptive Wide Angle filters.
I set a line as straight, mark as vertical (2 lines really) and then process.  The lines that are vertical come out wavy... best way to describe it..
I add the 2 control lines to the very outside most windows where the windows meet the brick... This is a closeup of the output...   I don't know when straight lines became waveforms.. but they do with this filter!
Thoughts?
    May 25, 2012 11:07 PM   in reply to tallguyjim72
    The tool does have its limitations.  It should only be used on images that have not already had their lens-distortion corrected and only on images that are still the full-extent of the sensor pixels.  If you’ve already cropped the image or its distortion has already been fixed, then the lens-model isn’t going to match and things won’t work, right?
