MikeKens
Where is the download link
May 26, 2012 10:53 AM
Hi
Seems that the system is programmed to make things difficult.  Trial DOWNLOAD button for Acrobat Pro (http://www.adobe.com/cfusion/tdrc/index.cfm?product=acrobat_pro&loc=en) has no hyperlink.  I have signed in, etc. etc.  There simply is no hyperlink.  Have tried of different internet access systems - same problem.  Please advise what I can do.  Have wasted about 90 minutes so far.
Thx
Mike K
    May 26, 2012 10:54 AM   in reply to MikeKens
    Branching this out to a new discussion as the previous thread was regarding the Adobe Download Assistant not responding.
    MikeKens I would recommend trying a different web browser.  It is likely your security settings, add-ons, or toolbars which might be causing your difficulties.
    May 27, 2012 10:56 PM   in reply to MikeKens
    Hi Mike,
    There should have been a yellow "Download now" button near the bottom of the page. Clicking the button normally starts the download process. Something on your computer is probably not letting letting the hyperlink get created.
    Could you check that the following are enabled in your browser:
    Now there might be several reasons, coudl you check if the following are enabled
    Also if you'll give some details about your computer/browser, it might help figuring out which component is misbehaving.
    May 28, 2012 12:17 AM   in reply to MikeKens
    Hi Mike,
    I really am sorry that you're facing an issue downloading the software. And I can understand your frustration. But I still need your help in figuring out what could be going wrong.
    I just completed initiating downloads on several computers and everything seems to work fine here. The download mechanism for CS6 and Acrobat is a little different, so I think that we still need to verify a few things.
    To help me troubleshoot this issue, could you do the following and let me know what happens:
    1. Click the Download now link.
      1. If you're not signed-in, are you prompted to sign in
      2. If you're alreday signed-in, does a browser window pops up. ( If it doesn't, could check if pop-ups are blocked, or is a notification waiting somewhere on your browser that pop-ups are blocked.A window similar to the obe below shoudl display.
    Or try a direct download from one of our community sites. As this is a fairly large download, I'll suggest using the Akamai Downlaod Manager though.
    http://prodesigntools.com/adobe-acrobat-x-10-pro-reader-suite-direct-d ownload-links-ddl.html
    Let me know how it goes. And I am sorry again for all the trouble you have to go through to download the software.
    Jun 7, 2012 9:49 PM   in reply to Vikrant Rai
    I am now having this problem too. Nothing happens when I click 'download now' any advice??????????????????????
    Jun 7, 2012 9:50 PM   in reply to MikeKens
    Hi Mike,
    Were you able to get this problem fixed? I now have the same problem.
    Victori
    Jun 7, 2012 10:52 PM   in reply to MikeKens
    Hi
    Thanks for your quick reply!!! I went to the prodesigntools website, and downloaded the acrobat program:
    AcrobatPro_10_Web_WWEFD
    But, i tried to open it but it won't open anywhere. It just says that the type of file is 'file' and it is an adobe extractor. So I need to choose a program to open it with... Did I do this wrong?
    Victoria
    Jun 7, 2012 11:06 PM   in reply to MikeKens
    Hey,
    Sorry, don't worry. I just renamed the file with .exe after it. And then it worked. I just need to figure out how to work the program now.
    Thanks very much for your help!!!!!!! Much better than the adobe people
    Victoria
