creating a button
May 25, 2012 5:51 AM
Is there any way to convert this to a submit button?  here is my code:
<a class="button small red" href="#" id="submitUpload"><span>Submit</span></a>
I followed this tutorial: http://acrisdesign.com/2011/06/create-a-multi-color-and-size-css3-butt ons/#
    May 25, 2012 11:10 AM   in reply to future-architect
    <a class="button small red" href="#" id="submitUpload" onclick="document.forms['formName'].submit();"><span>Submit</span></a >
    May 26, 2012 9:13 AM   in reply to future-architect
    Yes, that would only work with javascript enabled.  If you want to cover both eventualities, you could put a normal submit button inside a pair of <noscript> tags - then you'd have to figure out how to hide the other button when there is no javascript enabled.
    May 26, 2012 12:20 PM   in reply to future-architect
    Is 'fileUpload' the name of your 'file' field?  You would have to test for that this way -
    if($_FILES['fileUpload']) {
    May 27, 2012 5:15 AM   in reply to future-architect
    Sorry for my previous goofy answer.  The data was staring me in the face and I missed it!
    Try making your code look like this -
    onclick="document.forms['fileUpload'].submit();"
    You need the name of the form being submitted in that location, not the name of a field.
    May 27, 2012 8:02 AM   in reply to future-architect
    Now you've confused me.  The PHP would have to be conditional on some element that is present in the $_POST array.  The form name is not. So, if(isset($_POST['form_field_name']) && $_POST['form_field_name'] == 'some_value') { ?>
    The javascript would submit based on the form's name attribute value, i.e., document.forms['fileUpload'].submit();
    May 27, 2012 8:40 AM   in reply to future-architect
    I would use this -
    <?php if (array_key_exists('some_field_name', $_POST) {
    //processing code follows
    So far, we don't know the name of any of your form's fields - I usually use the name of the submit button, but you could also have a hidden or visible field with a name that you use here.
