Khmer Unicode for Premiere Pro CS5 / CS6 MAC OS X
May 25, 2012 3:06 AM
Tags: #cs5 #x #pro #lion #mac #osx #premiere #khmer #cs6 #premier #unicode #os #oxs
Hello every body,
For MAC OS X  Lion
I tested "Khmer Unicode" with Adobe Photoshop CS5 and it works fine but about Adobe Premiere Pro CS5 / CS6 does not work correctly.
Can you help me please?
Thank.
Bonjour tout le monde,
Sur MAC OS X Lion...
J'ai testé Khmer Unicode sur Adobe Photoshop CS5 et il fonctionne correctement mais sur Adobe Premiere Pro CS5 / CS6, il ne marche pas correctement.
Pouvez vous m'aider svp ?
Merci.
    May 25, 2012 10:19 AM   in reply to PCREVO77
    Moving this discussion to the Premiere Pro CS5, CS5.5, & CS6 forum.
    May 26, 2012 12:38 PM   in reply to PCREVO77
    Vous serait peut-être mieux servis lors de ce forum http://forums.adobe.com/community/international_forums/francais
    Jan 4, 2013 9:23 AM   in reply to Jerry Klaimon
    J'ai le même problème avec PP CS6: quelqu'un a t'il une solution?
    Jan 4, 2013 2:01 PM   in reply to eraim2
    Pardon ma Francais.  Faites tout les titres dans Photoshop seulement. Il est possible que vous ne devez "Rasterize" avant importez le PSD à Premiere Pro.
    Make all titles in Photoshop only.  It's possible that you'll have to Rasterize the text before importing into Premiere Pro.
    Jan 5, 2013 1:45 AM   in reply to Jeff Bellune
    Many thanks Jeff, don't worry for your French, I do speak/write/understand English as well and your French is not that bad - 100% comprehensible.
    I found a font that I like and appears to be correct with Photoshop (downloaded "Nida Funan"). However I don't know much of Photoshop and can't find if it's possible to put a shade on the characters like in PP Titler. I usually set fill color in white or yellow and put a black shade.
    Jan 5, 2013 7:57 AM   in reply to eraim2
    By "black shade", are you referring to a drop shadow?
    Jeff
    Jan 5, 2013 9:21 AM   in reply to Jeff Bellune
    Yes, and thanks to your wording (I was looking for "shade" instead of "drop shadow") I found the way and already made some titles with Photoshop. I had problem with the rolling credit list but created a 1920 x 6480 pixels image and made it rolling with the motion effect .
    By the way, should I put the pixels/inch at 300 or less in Photoshop?
    Jan 5, 2013 10:42 AM   in reply to eraim2
    The PPI, and DPI (the former for display, and the latter for printing), will have no impact, when going to Video. They are ignored. In Video, it's only about pixel x pixel sizes.
    Good luck,
    Hunt
