sewillia
Creating a high class effect with food
May 26, 2012 1:41 PM
Tags: #photoshop #adobe #still_image #food #graphic_design #illustrations
Hi there, my apologies if this is the wrong place to ask questions like this but I like a food graphic found at the www.le28thiers.fr homepage and would like to use that effect with other foods like pastries and cakes. I'd also like to reflecate the lighting effect in the 'room'. Can anyone tell me how I can do this?
Thanks for your time.
    May 26, 2012 2:20 PM   in reply to sewillia
    Lots of techniques at play here, but the primary technique to this effect is the lighting for the setup. Looking at some of the other images, it could be a composite of a number of images, the reuse of the ice cubes is a good example or it could be the cubes were extracted from the main iamge. But my guess this is a multiple composite image, radial gradient layer for the red background Sperate layers for the logo and text. Patterned layer for the top of the background.
    Very nicely done....
  • Trevor.Dennis
    May 24, 2010
    May 26, 2012 2:57 PM   in reply to MikeKPhoto
    One of the best photography resources on the web are the http://www.studiolighting.net/ podcast archives. Nearly a hundred half hour interviews with some of the best professional photographers out there. I have learned some real gems of information from them (I generally put them on a pen-drive and listen to them in the car).
    http://www.studiolighting.net/lightsource-podcast-archives/
    Check out #53 with Lou Manna
    http://www.studiolighting.net/lightsource-photography-podcast-e053-lou -manna/
    But to summarise, Lou says that food is generally lit from above and behind using a large light source, and that appears to be how your example shot was lit.
    May 26, 2012 3:17 PM   in reply to sewillia
    My guess is they are real fruit with generous use of the clone tool and healing brush, the artist did indeed outdo mother nature for such flawless fruit
    May 26, 2012 3:31 PM   in reply to sewillia
    It's a composite image, multiple exposures shot with the light coming from different directions. The olives are lit from behind and front-right, the lime front left, the glass back left and probably a reflector at right, and so on. Then the different exposures are put together and blended. Probably one or two large soft-boxes, and reflectors.
    But the setup itself is just too much work to put together later, with all the transparency and reflectance, so that's probably real (but brushed up).
    Beautifully done, an expert at work.
  • Trevor.Dennis
    May 24, 2010
    May 26, 2012 3:42 PM   in reply to MikeKPhoto
    I live in Marlborough New Zealand, where the wine comes from, but we are also famous for olives and seafood (mussels and salmon). Nearly all of my commercial work is for the local wine and food industry, and I promise you that there is usually very little retouching required for something like a bowl of olives. If you have thousands of the things to choose from, you are going to cherry pick the best ones. One the other hand, I do a lot of bottle shots, and they do need a lot of retouching. I usually use a Canon 100mm macro lens on a 1DsMK3, and the results are _very_ sharp, and every tiny flaw becomes obvious.
    Wine bottles tend to have screw tops nowadays, but the beer bottles I do have the old fashioned tops.  The black tops always get damaged in the bottling process, and take some fixing up.   That is done with a mixture of hand painting and the smudge tool, together with some temporary masking (in the way that an airbrush artist uses masks).
