Kraichgau
Font size problem on Elements 10
May 12, 2012 9:40 AM
When I try to add text to a particular picture the font size appears huge  taking up half the screen.
Changing the font size only helps slightly even when I click the font down to 6. How do I correct this?
    May 12, 2012 12:54 PM   in reply to Kraichgau
    When the Text tool is selected, click the little arrow at the left of the Options Bar, and select "Reset Tool".
    Ken
    May 12, 2012 6:34 PM   in reply to Kraichgau
    Is this happening to only that one picture?  What are the image dimensions and pixels/inch?
    Ken
    May 12, 2012 7:19 PM   in reply to Kraichgau
    I'm at a loss then, for those particular files.  As a test, try opening one of them and using File...Save As and picking the same file, answering "Yes" to replace the existing file.
    Ken
    May 13, 2012 11:23 AM   in reply to Kraichgau
    Back to my earlier question:  what is the pixels per inch (PPI) of one of the failing files?
    Ken
    May 13, 2012 2:12 PM   in reply to Kraichgau
    Yep, it's the resolution that's causing the problem.
    Open the image, and use Image...Resize.  With all the boxes at the bottom checked, first change the "Resolution" to "72", then change the top units to "percent" and change the value to "100":
    Ken
    May 16, 2012 5:49 PM   in reply to Kraichgau
    The section I circled in the screenshot.
    Ken
    May 26, 2012 3:30 PM   in reply to Kraichgau
    Yep,  you can do a test on a directory with a few of those photos, using the Editor's File...Process Multiple Files and selecting the "Resize" option's "Resolution" setting.
    Ken
    May 26, 2012 4:30 PM   in reply to Kraichgau
    You're welcome.  Good luck!
    Ken
