Currently this page has this note under the Enabling Search Engine Safe URLs section: "Note: If you wish to use custom SES URLs, add the URL entry to the uriworkermap.properties file found in the wsconfig folder for your web server."
The "add the URL" should be "also add the URL". Note the addition of the word "also". This is so that users clearly understand that the web.xml entry is needed in addition to the uriworkermap.properties entry.
Thanks!,
-Aaron
1) Currently this page has this note, under the "Changing the log rotation settings" section: "The size of coldfusion-out.log and coldfusion-error.log is set to 20MB by deafult. You can change the size of the log in the neo-logging.xml file by changing the maxFileSize setting."
The "20MB by deafult" should be "20MB by default". And "the maxFileSize setting" should be "the maxOutLogSize setting".
2) Also under the "Changing the log rotation settings" section is this: "You can also change the maximum number of backups of coldfusion-out.log and coldfusion-error.log that ColdFusion takes during log rotation within the neo-logging.xml file. Change the maxBackSize setting."
The "Change the maxBackSize setting" should be "Change the maxOutFileBackup setting".
Thanks!,
-Aaron
