Was looking at the addition of a workflow step to queue/delay the activation of pages until an off-peak specified window, and had seen the Absolutetime AutoAdvancer as a process step, but wasnt aware of the appropriate criteria/format to use as input in the timeout. Anyone familiar with the correct time format or criteria to satisfy that need?
If no one has has experience with use of Absolute AutoAdvancer workflow process, any other recommendations on straightforward approach to delay the exit of a workflow step until a specific time each day?
We just want to ensure the activation step is not processed (cache isnt flushed) until after a peak traffic.
TIA,
David
The AbsoluteTimeAutoAdvancer reads a property named absoluteTime from the WorkflowData's MetaDataMap. It's used in the "Activate Later" and "Deactivate Later" workflows. The property is expected to be a long (or parseable to a long) containing the number of milliseconds since 1/1/1970 (typical Java Date stuff).
I don't think this is necessarily the best choice for the problem you're describing. What you might want to do is write a new class which extends from AutoAdvance and implements the AbsoluteTimeoutHandler interface (just like AbsoluteTimeAutoAdvancer). In this class's getTimeoutDate method have logic like this:
Date now = new Date();
if (inPeakPeriod(now)) {
return endOfPeakPeriod + 1 min; // timeout right after peak period ends
} else {
return -1; // timeout now
In other words, rather than determining whether or not the workflow should be delayed *when the workflow is initiated*, determine it when the delay step is executed. See http://dev.day.com/docs/en/cq/current/javadoc/com/day/cq/workflow/job/ AbsoluteTimeoutHandler.html for more information on this interface.
Hi Justin, I was wondering why the getTimeoutDate methods in only invoked while using participant steps. I looked at the code at it seems the ParticipantNodeHandler is only firing the publishTimeoutEvent while handling the node transition. I was wondering if this is the desired behavior or if this is a bug; if this is a bug is it resolved on CQ 5.5 ?. Thanks, Nicolas
I want a intermediate step that will allow to move to next step only after some date or time. Can I use AbsoluteTimeAutoAdvancer?
Do I need to write a scheduler and job for this implementation of Timed Step completion?
Please suggest.
