I have IE9 installed on Windows 7 64bit with all the latest updates. For some reason I cannot play videos from some websites like vimeo.com using IE9 but they play fine using Google Chrome. I have unistalled and reinstalled Flash player with no luck.
Thank you – I just figured it out. NVDIA Control panel lets you choose graphic drivers by program. As soon as I switched from automatically select to integrated graphics the problem stopped.
Thank you for all your help.
See if any of this helps:
Thank you – Checked both Flash player shows as installed correctly and Active X filter is off. Video crashes IE9 only on some websites
Can you describe your problem in more details? You wrote "cannot play videos from some websites" and "Video crashes IE9" - what exactly is happening? And can you provide a URL where you see that happening?
As soon as I try and play a video I get an alert that pops up and stats Internet Explorer has stopped working. Then tries to find a solution. After a few seconds it closes the website.
One of the web sites is :
http://vimeo.com/
I cannot play any video’s on this site. To make matters worse I have formatted my hard drive and installed only minimal amounts of software (Itunes & Microsoft Office 2010) and every windows update. The problem started happening right around the last few updates. I have tried to uninstall the last few but was not able to isolate this to fix the problem.
I am using a Lenovo W520 Laptop with Windows 7 Professional.
Can you try if disabling Hardware Acceleration improves the situation; see http://forums.adobe.com/thread/891337
If it does, then updating the device drivers for your display adapter could be a permanent solution; see http://forums.adobe.com/thread/945765
