Premiere to After Effects Possible Bug
May 27, 2012 3:29 PM
Just exprerienced a problem on my CS6 master collection. Since I have uninstalled my CS5.5 I can not see if this was present before.
Anyway here is what I have experienced.
I have a timeline in Premiere where all the clips are in reverse speed and each clip is dissolved into each other with opacity keyframes ( Each clip has in and out points).
When you copy all items in premiere and then paste it into a new composition in After Effects. Opacity keyframes are misplaced. I believe that after effects reads the keyframes as if the clips in premire were not in reverse speed.
Koray Birand
    May 27, 2012 6:00 PM   in reply to kbirand
    Don't do that.  Select the clips in PP, right click and choose replace with After Effects Composition...
    See if that helps.
    May 27, 2012 7:55 PM   in reply to kbirand
    OK.
    Keep the clips the proper speed in PP, and adjust that as needed in AE instead.
