Adobe Acrobat X Pro won't let me embed a video file which I created as
"MPEG4: iPhone H.264 (640x480)" in Corel Video Studio.
The video file plays fine in Windows Media Player, QuickTime, Corel Video Studio, and
Final Cut Express (on a Mac, which also displays "H.264 compression" in properties for the file).
Here's an analysis of the file from MediaInfo:
Format: MPEG-4; Format profile: Sony PSP;
Codec ID: MSNV; File size: 110 MiB; Duration: 6mn 0s;
Overall bit rate mode: Variable ; Overall bit rate: 2 556 Kbps; Video ID: 1;
Format: AVC; Format/Info: Advanced Video Codec; Format profile: Baseline@L3.0;
Format settings, CABAC: No; Format settings, ReFrames: 2 frames; Format settings, GOP: M=1, N=15;
Codec ID: avc1; Codec ID/Info: Advanced Video Coding;
Bit rate mode: Variable; Bit rate: 2 393 Kbps; Maximum bit rate: 2 500 Kbps;
Width: 640 pixels; Height: 480 pixels; Display aspect ratio: 4:3;
Original display aspect ratio: 4:3; Frame rate mode: Constant; Frame rate: 30.000 fps;
Standard: NTSC; Color space: YUV; Chroma subsampling: 4:2:0; Bit depth: 8 bits;
Scan type: Progressive; Bits/(Pixel*Frame): 0.260; Stream size: 103 MiB (94%);
Color primaries: BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177;
Transfer characteristics: BT.709-5, BT.1361;
Matrix coefficients: BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
I only have Adobe Acrobat X Pro CS5.5 and DreamWeaver CS5.5 (Educational/Academic versions),
and it seems I can't get Adobe Media Encoder separately. I have to get Adobe Acrobat X Suite or something similar.
Any ideas would be welcome.
Ivan Brown
University Lecturer
OK. Thanks for that. I'll try to find a way of saving as H.264 that isn't Sony PSP.
There was no way of knowing it was Sony PSP from within Corel Video Studio, but I guess that's an issue for a Corel VS forum...
One point, though: Adobe Acrobat X Pro does let me embed another video clip created in Corel Video Studio:
"MPEG4: iPod H.264" (320x240), and MediaFile also identifies this as Sony PSP (see below).
(But I want 640x480 resolution).
Complete name : G:\Documents\Research\学内研究プロジェクト\Short prog A Westminster\2010-2011\Grp1\ひな祭り\2011 ShortprogA iPod 320x240.mp4
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 12.4 MiB
Duration : 1mn 52s
Overall bit rate mode : Variable
Overall bit rate : 920 Kbps
Encoded date : UTC 2012-01-12 08:36:55
Tagged date : UTC 2012-01-12 08:36:55
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L1.3
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1mn 52s
Bit rate mode : Variable
Bit rate : 789 Kbps
Maximum bit rate : 768 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 30.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.342
Stream size : 10.6 MiB (86%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1mn 52s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 1.73 MiB (14%)
Language : English
Actually, I've found some FLV output options in Corel Video Studio, including 640x480.
There's some loss in sound resolution (48kHz to 22kHz) and it means doing a lot of video rendering work over again,
but it seems to work in Acrobat.
Thanks for your help, anyway.
