Auto update issues, no scheduled task.
May 25, 2012 9:08 AM
Tags: #flash #autoupdate #mms.cfg
I have sucessfully rolled out Flash 228 via Group Policy with the MSI package. That worked a treat. I also pushed out the mms file.
AutoUpdateDisable=0
SilentAutoUpdateEnable=1
AutoUpdateInterval=0
The issue I have is, it isn't updating. The update service has been installed, but not schedule task has been made.
Anyone got any ideas?
Best wishes
Michael
  • Chris Campbell
    May 4, 2010
    May 25, 2012 4:17 PM   in reply to bazcurtis
    Hi Michael,
    I'd be happy to help look into this.  Can you post your Flash installer log?
    Where do I find the Flash Player installation log on Windows?
    Chris
  • Chris Campbell
    May 4, 2010
    May 29, 2012 5:37 PM   in reply to bazcurtis
    Thanks Michael.  Unfortunately I forgot to have you enable SilentAutoUpdateVerboseLogging=1 in your mms.cfg file.  Would you mind doing that, give it a couple hours then post another log?
    Chris
  • Chris Campbell
    May 4, 2010
    May 30, 2012 4:30 PM   in reply to bazcurtis
    The scheduled task should be added regardless of the mms.cfg setting.  I'll see if the installer folks can take a look at your initial log.
    Chris
    May 31, 2012 10:17 AM   in reply to bazcurtis
    Hi Michael,
    Could you please add the FlashInstall.log file from the 32-bit location as well? This will allow us to isolate the issue. You can find it at C:\Windows\SysWOW64\Macromed\Flash.
    Stephen
    Jun 1, 2012 1:13 AM   in reply to Stephen Pohl
    i have a similar problem. I installed the 32bit version 11.2.202.228 on a win 7 64bit OS.
    The mms.cfg contains:
    AutoUpdateDisable=0
    But flashplayer won't update on its own. The Flashinstall.log shows this:
    =O====== M/11.2.202.228 2012-05-31+08-06-41.359 ========
    0000 [I] 00000010 "C:\Users\Test\AppData\Local\Temp\InstallPlugin.exe" -install -msi
    0001 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0002 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0003 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0004 [W] 00001036 Software\Opera Software/Plugin Path 2
    0005 [W] 00001036 Software\Opera Software/Plugin Path 2
    0006 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_2_202_228.dll
    0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_Plugin.ex e
    0008 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
    0009 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0010 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0011 [W] 00001102
    0012 [W] 00001106
    =X====== M/11.2.202.228 2012-05-31+08-06-44.124 ========
    =O====== M/11.2.202.228 2012-05-31+08-07-37.606 ========
    0000 [I] 00000010 "C:\Users\Test\AppData\Local\Temp\InstallAX.exe" -install -msi
    0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
    0002 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx
    0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.e xe
    0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.d ll
    0006 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0007 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
    0008 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
    0009 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0010 [W] 00001106
    0011 [W] 00001106
    0012 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
    =X====== M/11.2.202.228 2012-05-31+08-07-42.418 ========
    2012-6-1+6-11-5.777 [info] 1614
    2012-6-1+6-11-11.652 [info] 1615
    2012-6-1+6-11-11.824 [info] 1618
    2012-6-1+6-11-11.839 [info] 1619 1063
    2012-6-1+6-11-11.871 [info] 1614
    2012-6-1+6-11-11.871 [info] 1615
    2012-6-1+6-11-11.871 [info] 1618
    2012-6-1+6-11-11.886 [info] 1608
    2012-6-1+6-11-11.886 [info] 1604
    2012-6-1+6-11-11.949 [warning] 1403 12007
    2012-6-1+6-11-11.996 [warning] 1407 183
    2012-6-1+6-11-11.996 [warning] 1408
    2012-6-1+6-11-13.402 [info] 1626
    2012-6-1+6-11-13.417 [info] 1612
    2012-6-1+6-11-13.417 [info] 1621
    2012-6-1+6-11-13.417 [info] 1620
    2012-6-1+7-11-8.362 [info] 1614
    2012-6-1+7-11-10.3 [info] 1615
    2012-6-1+7-11-10.284 [info] 1618
    2012-6-1+7-11-10.503 [info] 1619 1063
    2012-6-1+7-11-11.393 [info] 1614
    2012-6-1+7-11-11.393 [info] 1615
    2012-6-1+7-11-11.393 [info] 1618
    2012-6-1+7-11-11.393 [info] 1608
    2012-6-1+7-11-11.425 [warning] 1403 12007
    2012-6-1+7-11-11.425 [warning] 1407 183
    2012-6-1+7-11-11.425 [warning] 1408
    2012-6-1+7-11-11.925 [info] 1604
    2012-6-1+7-11-14.831 [info] 1626
    2012-6-1+7-11-14.831 [info] 1612
    2012-6-1+7-11-14.846 [info] 1621
    2012-6-1+7-11-14.846 [info] 1620
    Any Ideas?
    Martin
    Jun 1, 2012 10:37 AM   in reply to AtosHille
    Hi Martin,
    Your log shows that the Background Updater is successfully starting up and attempting to check for updates. However, your system doesn't seem to be able to connect to Adobe's backend. Please make sure that you permit connections to port 80 on fpdownload2.macromedia.com and port 443 on fpdownload.macromedia.com.
    To run a quick check, please open a web browser and try connecting to the following URLs:
    https://fpdownload.macromedia.com/pub/flashplayer/update/current/sau/1 1/xml/version.xml
    http://fpdownload2.macromedia.com/pub/flashplayer/update/current/sau/1 1/install/install_all_win_pl_sgn.z
    If you want to continue restricting access to these ports/domains, you might want to consider hosting updates to Flash Player on your internal network instead. You can refer to my blog post here for instructions on how to set this up.
    -Stephen
    Jun 1, 2012 10:44 AM   in reply to bazcurtis
    Hi Michael,
    On a 64-bit Windows system, you will want to place your mms.cfg file in:
    An mms.cfg file that is placed in C:\Windows\System32\Macromed\Flash will be ignored on 64-bit Windows. If there is one there, feel free to remove it to avoid confusion in the future. It has no bearing on the installers, updaters, or Flash Player itself. Only on 32-bit Windows systems will the mms.cfg be placed in C:\Windows\System32\Macromed\Flash.
    Your log shows that you successfully connected to the Adobe backend and that the Background Updater attempted to download the updates. However, the download and verification of the updates failed. Please make sure that you can connect to the following URLs from a web browser on the affected system (and that you don't get a 404 or similar error):
    http://fpdownload2.macromedia.com/pub/flashplayer/update/current/sau/1 1/install/install_all_win_ax_sgn.z
    -Stephen
    Jun 5, 2012 3:27 AM   in reply to Stephen Pohl
    Hi Stephen,
    thanks for the quick reply!
    Both Links are reachable.
    We have a internet security program called webwasher (McAfee) running, I've made a request to make sure, that the links are not blocked in any way, but have not got an answer yet.
    Martin
    Jun 13, 2012 10:31 AM   in reply to bazcurtis
    Hi Michael,
    Which version of Flash Player do you have installed, and which version do you expect to be updated to?
    Stephen
    Jun 15, 2012 3:25 PM   in reply to bazcurtis
    Hi Michael,
    It would be great if you could send us your latest FlashInstall.log. This would help us identify where this is still failing. This still appears to be a connection problem, maybe to the installers this time.
    Stephen
    Jun 21, 2012 10:24 AM   in reply to bazcurtis
    Hi Michael,
    Yes, Flash Player on Mac now supports the Background Updater as of version 11.3.
    -Stephen
    Jun 21, 2012 10:27 AM   in reply to bazcurtis
    Hi Michael,
    This seems to be due to the fact that the release of 11.3 was a scheduled release. For scheduled releases, the current Adobe policy intends to notify users of the update for a period of time (currently 30 days) before updating automatically. More info can be found here: http://helpx.adobe.com/flash-player/kb/flash-player-background-updates .html
    -Stephen
    Jun 21, 2012 5:35 PM   in reply to Stephen Pohl
    What about the latest release 11.3.300.262 ?
