Can't Convert Old Panel?
May 24, 2012 12:03 AM
Tags: #3 #configurator #failed_to_write
I have a panel I created in Configurator 2.0 and I am trying to convert it to CS6 compatible version and it give me an error saying Failed to write. What can I do to convert my panel?
    May 24, 2012 4:03 AM   in reply to Lynda Spangler
    In Configurator 3 open your panel and from the Edit menu select convert o CS6. If that does not work please reply on the forums or log a bug.
    May 24, 2012 8:35 PM   in reply to Lynda Spangler
    If Configurator 3 can't read or back up the Configurator 2.0 panel at the same directory, the it pops up error message as :"Failed to write".
    Coule you please check the permission of the directory ? Is it a system directoy that Configurator 3 doesn't have the permission to write?
    Try to lauch Configurator 3 as Admistrator if it is Windows OS.
    If it still doesn't work, could you please send your Configurator 2.0 design panel to us? Please send the ".pgc" file and the corresponding ".assests" folder together.
    May 24, 2012 10:45 PM   in reply to Lynda Spangler
    Is this old 2.0 panel file can be opened correctly by Configurator 2.0?
    If yes, please send us your old 2.0 panel file with “.gpc” file and “.assets” folder together to xguo@adobe.com<mailto:xguo@adobe.com> directly.
    Or you can file a bug to Configurator 3 and attach the “.gpc” file and the “.assets” folder.
    If yes, please send us your old 2.0 panel file with “.gpc” file and “.assets” folder together to xguo@adobe.com directly.
    May 28, 2012 12:39 AM   in reply to Lynda Spangler
    You can solve this issue by following these steps:
    1. Open your panel with Configurator 2.0
    2. Remove the button "Dust and Scratches" under "Filters" category
    3. Save and close
    4. Open the panel with Configurator 3 to convert to CS6 panel
    6. Drag and drop the command "Dust & Scratches" (Main->Filter->Noise->Dust & Scratches) to place where it is removed in step 2
    Because the id of this command contains '&' and the escaped '&amp;' is used internally for converting. We will fix this bug in next version. These commands will also suffer from this issue:
    Edit-Preferences-TransparencyandGamut
    Edit-Preferences-UnitsandRulers
    Edit-Preferences-Guides,Grid,SlicesandCount
    Image-Adjustments-BlackandWhite
    Layer-LayerStyle-BevelandEmboss
    Layer-NewAdjustmentLayer-BlackandWhite
    Filter-Noise-DustandScratches
    Filter-Sketch-ChalkandCharcoal
    Window-Workspace-KeyboardShortcutsandMenus
