add multiple page
May 28, 2012 4:42 AM
to see if anyone can help me.
I need to define a script, to create multiple pages.
at the moment:
it is believed only one:
the code is this:
var myDoc = app.activeDocument;
var myPg = myDoc.pages.item(-1);
var myLastPage = myDoc.pages.add.(LocationOptions.AT_END, myPg);
thanks to all !
    May 28, 2012 4:55 AM   in reply to Raul_rubi
    Hi Raul,
    Your script is working fine, the error is pages.add.
    Raul_rubi wrote:
    at the moment:
    the code is this:
    thanks to all !
    var myLastPage = myDoc.pages.add(LocationOptions.AT_END, myPg);
    thx
    csm_phil
    May 28, 2012 5:12 AM   in reply to Raul_rubi
    Hi Rubi,
    The problem is you using the period character after the add text before. so this is the problem.
    For your information if the anwswer is right please check the right answer otherwise lot of people go and read your thread that is waste of time. please do the process yes or no.
    thx
    csm_phil
    May 28, 2012 5:17 AM   in reply to Raul_rubi
    Is your problem that thhe script only adds a single page? That's easily fixed.
    By the way, if you use AT_END you don't need to supply an additional pointer, the new page will always end up there.
    Untested but this ought to work:
    var addPages = 6;
    // Save first added page ...
    var myFirstAddedPage = myDoc.pages.add(LocationOptions.AT_END);
    addedPages--;
    while (addPages > 0)
       addPages--;
    ..  'myFirstAddedPage' will point to the first one of your newly added pages.
    May 28, 2012 5:20 AM   in reply to csm_phil
    Hah -- I saw that in my code and thought, "huh why did I do *that*!?" (I copied a part of the original.)
    Raul, it would have helped if you told us *why* your code failed! The error message would have indicated this mistake right away.
    May 28, 2012 7:23 AM   in reply to Raul_rubi
    Raul_rubi wrote:
    I can not create multiple pages
    Please tell us why not! Help us to help you!
    But, I'm back behind my computer so let's see what's wrong. Running my script now -- oops.
    JavaScript Error!
    Error Number: 2
    Error String: addedPages is undefined
    File: ...
    Line: 5
    Source: addedPages--;
    Well, that's pretty clear. I mis-typed 'addedPages' on that line, it should have been 'addPages'. With that corrected, the script does indeed add 6 empty pages at the end of my current document.
    May 28, 2012 8:19 AM   in reply to Raul_rubi
    That's different from what I understood from your original post, but ... still no problem. Instead of AT_END, which does what it says, use AFTER (this *also* does what it says):
    var addPages = 6;
    // Page number 2 is item(1), since page number 1 is item(0):
    var addAfter = app.activeDocument.pages.item(1);
    var myFirstAddedPage = myDoc.pages.add(LocationOptions.AFTER, addAfter);
    addPages--;
    // .. then add the others AFTER it as well
       addPages--;
       myDoc.pages.add(LocationOptions.AFTER, myFirstAddedPage);
    May 28, 2012 8:48 AM   in reply to [Jongware]
    You type too quickly jong although I did do it slightly different…
    app.activate();
    var midPage = myDoc.pages.middleItem(); // some middle ref
    var addPages = 6;
    do {
        myDoc.pages.add( LocationOptions.AFTER, midPage );
        addPages--;
    } while ( addPages > 0 )
    Just edited that app.activate which was clearly wrong… needed ()
