I need help
May 28, 2012 9:48 AM
Hello,
I am currently learning how to use actionscript3.0. to design a space invader game which i need to carry our a study. I have manageg to maake the player shoot bullet upward. I have also populated my Aliens (50) on the screen and they can moove horizontally. Now  my problem is how to make the aliens move downwards when they hit both sides of the screen. Any suggestions would be appreciated.
    May 28, 2012 10:18 AM   in reply to chiggy83
    Conditions could be using
    I think there may be problems depending on how you group or not the aliens.
    The basics would be that when any alien touched the edge of the screen some all aliens are increased in height and alien (with this would lower).
    if (aliensGroup.x <0) {
         aliensGroup.x = 1;
         aliensGroup.y + = individualAlien.height;
    if (aliensGroup.x> aliensGroup.width) {
         aliensGroup.x = aliensGroup.width-1;
    * That if the registration point is top left.
    But what if they destroy the entire first column of aliens?
    You would have to move all the aliens on the left
    But know what aliens are on stage?
    Maybe you would have to take into an array references for each alien and remove this of the array when it is destroyed
    May 28, 2012 11:05 AM   in reply to chiggy83
    Try with this:
    var alien_direction:Number = 1.5;
    var alienArray:Array = new Array();
    var columns = 10;
    var rows = 5;
    var HspaceBetweenInvaders = 60;
    var VspaceBetweenInvaders = 40;
    for (var i:int=0; i<columns; i++)
        for (var j:int=0; j<rows; j++)
            var alien_mc:mcAlien = new mcAlien();
            alien_mc.x = i * HspaceBetweenInvaders + 55;
            alien_mc.y = j * VspaceBetweenInvaders + 150;
            addChild(alien_mc);
            alienArray.push(alien_mc);
    addEventListener(Event.ENTER_FRAME, onEnterFrame);
    function onEnterFrame(event:Event):void
        for (var i:int = 0; i< alienArray.length; i++)
            if (alienArray[i].x > stage.stageWidth)
                alien_direction = -1.5;
                 down();
            else if (alienArray[i].x < 0 )
                alien_direction = 1.5;
                down();
            alienArray[i].x = alienArray[i].x + alien_direction;//move to the right
            //alienArray[i].y =  -alienArray[i].y
    function down():void {
            alienArray[i].y += 5    //VspaceBetweenInvaders + 150;
    May 28, 2012 11:22 AM   in reply to esdebon
    Indeed the condition would be better this way
    if (alienArray[i].x < 0 || alienArray[i].x > stage.stageWidth)
                alien_direction * = -1;
                 down();
    May 28, 2012 3:18 PM   in reply to chiggy83
    could you give me the size of the stage you use, and the size of your alien in order to reproduce the problem
    May 28, 2012 3:42 PM   in reply to chiggy83
    The last code works fine to me, buy maybe this solve your problem
    var columns = 10;
    var rows = 5;
            addChild(alien_mc);
        for (var i:int = 0; i< alienArray.length; i++){
            if (alienArray[i].x+alienArray[i].width > stage.stageWidth){
                down();
            else if (alienArray[i].x < 0 ){
                down();
    function down():void{
        removeEventListener(Event.ENTER_FRAME, onEnterFrame);
            alienArray[i].y +=  5;//VspaceBetweenInvaders + 150;
    May 29, 2012 8:24 AM   in reply to chiggy83
    function onEnterFrame(event:Event):void{
           (Math.random()*100<10)?shoot(i):null    // each frame 10% probability of shot
          // more code
    function shoot(i):void{
         var shoot:Shoot=new Shoot();  // Object from the library
         shoot.x=alienArray[i].x
        shoot.y=alienArray[i].y
    Jun 5, 2012 7:57 AM   in reply to chiggy83
    this line
    is same to:
    if(Math.random()*100<10){
         shoot();  // you need create this function
    where Math.random()*100 is a number between 0 and 100
    then each frame have a 10% of probability of shoot
    Jun 5, 2012 8:46 AM   in reply to chiggy83
    // make aliens drop bombs randomly
                                  for (var bombNumber:int = 0; bombNumber< alienArray.length; bombNumber++)
                                                           var random:Number = Math.random();
      var bombArray:Array = new Array();
    function shoot():void
                                       // create bombs and put them in array
                                                 var bomb_mc:mcBomb = new mcBomb();
                                                addChild(bomb_mc)
                                                 bomb_mc.x = alienArray[i].x;
                                                 bomb_mc.y = alienArray[i].y
                                                 bombArray.push(bomb_mc);
    addEventListener(Event.ENTER_FRAME,moveBombs)
    function moveBombs(e:Event):void{
                        bombArray[i].y += 10;
