tmewborn
Slow to switch between layers
May 25, 2012 4:26 PM
The panels look great, but I have the same problem I had in Configurator 2. With a panel open it is slow to move between layers, with no panel it moves instantly. I use a lot of layers and switch between them often.
I am using an I7, 16 gigs of ram, win 7 64 bit and an advanced video card with the latest driver.
Tom
    May 28, 2012 12:18 AM   in reply to tmewborn
    I tried this on my side and cannot reproduce this.
    I created a simple Configurator panel and then export and open it in Photoshop CS6.
    Then I new a Photoshop file and added about 15 layers to this file.
    After I keeping the Configurator panel open, I tried to switch between those layers and there is no obvious lag there.
    Are you facing this kind problem with a special Configurator panel or each Configurator panel?
    If it is a special one, could you please share your panel with us for a further investigation?
    You can send your panel (the .gpc file and the corresponding .assests folder) to xguo@adobe.com
    BTW, is it fine to ask for a photoshop panel with lots of layers of yours to us ?
    Xiaoyan
    May 28, 2012 7:16 PM   in reply to tmewborn
    Never mind:)
    Thanks for your support in Configurator .
    Xiaoyan
    Apr 3, 2013 3:37 PM   in reply to guoxy
    I'm getting this same issue on two different Windows 8 machines with Photoshop CS6 with any panel I create in Configurator 3... Also, this same issue happens, for example, with a panel I didn't create, the HTML Sample Panel from Adobe, downloaded from the Adobe Exchange Panel.
    When you don't have the panel open from start, click between your layers in the Layers panel.  They should highlight instantly.  When you open a panel created as described above, there is a big delay between selecting different layers. You can not resolve this unless you close the extension panel and restart Photoshop.
    Is there a solution for this?  Obviously a big problem.
    I also just tested a panel built on a Mac and loaded on Windows with CS6...no fix, same isssue.
    Note, this issue is not happening on Mac with CS6.
    Thank you.
